Pulsating Feel
Old Mar 29, 2005 | 03:53 PM
wolfmd's Avatar
wolfmd
Default Pulsating Feel
I'm sure this has probably been brought up before...
When braking, as I get closer to stopping I can feel a "pulsating" (and for all you wiseguys... no, it's not in my pants). Is this usual/normal or is there possibly a warped rotor issue here?
Appreciate any insight from others who have experienced the same.
Old Mar 29, 2005 | 04:28 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Rotor warpage seems to be a issue that's common. Get them turned or replaced, new pads and see how that helps. Many just replace with drilled and slotted rotors for appearance and a better feel
Old Mar 29, 2005 | 04:48 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Mar 29, 2005 | 04:53 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Who is changing your wheels?
Old Mar 29, 2005 | 05:21 PM
Sounds like a warped rotor to me.
Old Mar 29, 2005 | 05:32 PM
napacruzerc5's Avatar
napacruzerc5
Isn't this part of the ABS working under hard braking and not necessarily a problem with warped rotors?
Old Mar 29, 2005 | 05:41 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
no, the pedal shouldn't "pulse" under normal braking, it's a different feeling when ABS kicks in.
I'd have to go with the warped rotor diagnosis.
Old Mar 29, 2005 | 05:55 PM
Epicman's Avatar
Epicman
how much are drilled/slotted rotors?
Old Mar 29, 2005 | 08:31 PM
wolfmd's Avatar
wolfmd
I don't feel this during hard braking. Only as I'm just about to a stop.
To Pulsating Feel
