Question on Techron Use.
Mar 29, 2005 | 09:57 PM
I bought a bottle of Techron the other day as advised by many on this forum, but ahave a few questions on its use:
1.) Should it be added to a full tank or empty tank then filled?
2.) Does it need to be done before an oil change? I am just finding some threads stating that it effects the oil. I just changed my oil!
I have a 2001 with 11,000 miles on it.
Mar 29, 2005 | 10:06 PM
-Instructions say to add bottle then gas, mixes better/faster. I have done both ways.
-Don't see how it would affect oil (without ring blow-by), especially if you don't use any oil.
Mar 29, 2005 | 10:07 PM
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
I add it after fill... a bottle every 3K
Mar 29, 2005 | 10:28 PM
I ask about the before or after filling because of the dual tanks. If added empty, will it go into both tanks and vice versa?
Mar 29, 2005 | 10:29 PM
Instructions say to add before filling with up to 12 gallons of gas.
Mar 29, 2005 | 10:34 PM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
add before the gas, just like the rum goes in before the cola - it will distribute to both tanks faster that way.
Mar 29, 2005 | 11:03 PM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Quote:
Mar 29, 2005 | 11:15 PM
You can also just fill up with Chevron 93 it has Techron in it.
Mar 30, 2005 | 01:03 AM
No matter how you "mix" it, I think you need to drive it MORE!
All the best.
Mar 30, 2005 | 01:28 AM
Quote:
You beat me to it....
Mar 30, 2005 | 02:02 AM
All the best.
Just dont drive it as much as I do mine. When I picked up my 98 at the end of July 04, she had 14,100 on it. Now, she has around 28K
Mar 30, 2005 | 02:20 AM
I put the stuff in my vette, they say to change the oil after to clean all the deposits you just washed out of the fuel lines and engine. How true this is i don't know, but i could image if your valves were really dirty, some of the carbon cleaned from them could get onto the cylinder wall and then into the oil. Anyone?
Mar 30, 2005 | 06:23 AM
Put it in, then fill her up. Will distribute the stuff to both tanks faster.
Mar 30, 2005 | 06:50 AM
Oldtimer
Now there's a great analogy.
Mar 30, 2005 | 07:54 AM
I do the same...before gas, about once every three months.
hhntr111
