Stock exaust tips
Old Mar 30, 2005 | 09:20 AM
BlackArrow's Avatar
BlackArrow
Default Stock exaust tips
How do you clean/polish the stock exaust tips on a 02 coupe? Mine have some stains and carbon deposits. What type of chemical cleaners etc can you use, I assume that the material is a stainless steel.
Old Mar 30, 2005 | 10:34 AM
ALLEGRO's Avatar
ALLEGRO
Use a light "Polishing Compound" to remove the stains and then wax to protect the surface.
Should be good!
Old Mar 30, 2005 | 12:58 PM
Use Mothers Mag/Aluminum Polish - it works well on my exhaust tips.
Old Mar 30, 2005 | 01:07 PM
BickyDhadwal's Avatar
BickyDhadwal
Should be good!
Old Mar 30, 2005 | 03:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Mar 30, 2005 | 04:04 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Nevr-Dull.
Remarkable stuff.
Larry
code5coupe
Old Mar 30, 2005 | 08:47 PM
Ken1234's Avatar
Ken1234
Here is how you clean them.
Replace with a mod set, such as Corsa, Borla, etc. The stock pipes do your car no justice. Spend the $, replace them.
Old Mar 30, 2005 | 08:50 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I use the new Meguiars NXT All-Metal polish. Works great!
If that fails, I strongly recommend an aftermarket exhaust system of your choice....just don't ask which one is best!
Old Mar 30, 2005 | 09:25 PM
BlackArrow's Avatar
BlackArrow
O.K., then I'll ask which one is the quietest.....I don't need loud....I'm an old geezer and I have owned too many loud exaust cars...a 66 SS 396, 57 Chev, 58 348 Tri-power, and a Ford diesel cab over truck. Just want good looks.
Old Mar 30, 2005 | 09:35 PM
Dark-Knight's Avatar
Dark-Knight
Try Mothers Mag Wheel Cleaner..
Old Mar 30, 2005 | 10:15 PM
blacksedan87
If you want quiet - stay with stock. If you want to improve the appearance of the tips, look into aftermarket tips by someone like Corsa.
If you want to upgrade to a quiet rumble, think about a set of used Z06 Titanium.
Prolly next step up from there would be a Corsa Touring.
From there the sky is the limit! My humble $.02 deposited.....
To Stock exaust tips
