Gear Ratio Help!
Old Mar 30, 2005 | 08:06 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Default Gear Ratio Help!
Someone has posted a table here that shows rpm/mph that can tell you what rear ratio you have. Anybody got it?
Old Mar 30, 2005 | 08:57 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Mike Mercury had that table on his web site, but I can't find the link.
Basically if you run an A4 - put the car in 3rd, take it up to 75mph. The rpm's will be 2730 if you have a 2.73 - 3150 if you run the 3.15.
If you have the MN6 - use 4th.
The idea is to get into the gear that is a 1:1 ratio.
I know someone will correct me if I'm wrong, but I believe that's how it works.
Old Mar 30, 2005 | 09:26 PM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/ratio.htm
Old Mar 30, 2005 | 10:27 PM
JACKAL0PE's Avatar
JACKAL0PE
Thanks guys. That's exactly what I was looking for.
To Gear Ratio Help!
