Delco Battery or not
Old Mar 30, 2005 | 08:45 PM
caffeine's Avatar
caffeine
Default Delco Battery or not
My 99 is going in for the spring tune up. It has the original 99 AC Delco Battery in it, and I think it's time for a new one. Can I stick with a new AC Delco battery in it or do I have to go for an aftermarket.
Suggestions?
Old Mar 30, 2005 | 08:50 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
You don't HAVE to stick with a Delco. Most owners here switch over to a red top.
Old Mar 30, 2005 | 08:53 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You can do anything you wish. Many folks here like the sealed gel-type batteries, to avoid the potential for a leaky mess.
Personally I run the Optima Red-Top 75/35 that I bought at Costco for $99. It has worked great for me, although there are some members who state they've had issues......
Old Mar 30, 2005 | 09:00 PM
caffeine's Avatar
caffeine
Do the new Delco Batteries have the potential to leak?
Old Mar 30, 2005 | 10:04 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Yes it could leak.
Optima Yellow Top here ... but I heard one fizzled a while back, so no guarantee there either.
Old Mar 30, 2005 | 10:08 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Red Top is my choice by any gel type battery will work. Read the threads about computer damage from a leaky battery and you'll see why.
Old Mar 30, 2005 | 10:39 PM
mhaber's Avatar
mhaber
AC Delco no longer makes the absorbant gel battery. They now have the professional series. I had one put in on warranty last year and no problems so far. It can leak so I'm watching it like any other battery. I will switch to an Optima Red Top from Costco when I need to replace it.
Old Mar 30, 2005 | 10:59 PM
caffeine's Avatar
caffeine
2 Questions:
Is this the correct model # for a 1999 Vert?
Does anyone know if Costco in Canada carries it or where I can buy it?
Old Mar 30, 2005 | 11:18 PM
blacksedan87
The 75/35 Red Top to which I referred will be a perfect replacement for your 99 (I have a 98). There is also a second battery - the 34/78, which is dimensionally slightly larger, but will fit.
The 75/35 is 720 cold cranking amps, the 34/78 is 800 c.c.a.
The 34/78 can be identified by having the side terminals closer together, where the 75/35 has the side terminals all the way out to the edge. Again, either one will be a direct replacement.
This is from Optima's web site....
http://www.optimabatteries.com/publi...ry_search.html
CHEVROLET
Corvette
2000-1997 All
Alternative Selections:
Part Number: YEL34/78
CCA: 750
Model Name: Optima
Battery Group Size: 34DTO
Part Number: RED34/78
CCA: 800
Model Name: Optima
Part Number: RED75/35
CCA: 720
Model Name: Optima
Battery Group Size: 75DTO
As far as where to purchase, sorry but I can't help you. If there is Costco in Canada (I didn't know that!), I would imagine they would carry it. Why not give them a call.....
Old Mar 30, 2005 | 11:23 PM
Sure you can go with the Delco. I chose to go with an Optima Red Top (34/78) and have not regretted it.
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
My choice as well.
Old Mar 30, 2005 | 11:28 PM
birch64's Avatar
birch64
has anyone ever called optima? i called today and they told me the battery for corvettes is the 34/78. thats the one with a perfect fit..........i looking for a new battery and costco in schumburg, il. told me they dont carry the 34/78 red top? also heard it's tough getting the cables attached to the closer terminals..........what are most people using? thanks
Old Mar 31, 2005 | 12:35 AM
stevzc5's Avatar
stevzc5
I got one at Sam's Club for about $102. It was marked as 34U, and I called Optima and they said this was the 34/78. It fit perfectly, and no problem fitting the cables. I suggest making sure you get the Optima hold down bracket as it fits around the battery better. Optima makes a top cover for this model, which snaps on and gives a more finished look. I got mine at Mid America for about $18.
Old Mar 31, 2005 | 06:05 AM
jman1's Avatar
jman1
Old Mar 31, 2005 | 07:56 AM
Tom/99's Avatar
Tom/99
When I replaced the battery in my 99, I went back with another Delco.
Old Mar 31, 2005 | 10:00 AM
caffeine's Avatar
caffeine
Thanks for everyone's help. Optima ordered!
To Delco Battery or not
