Wheel Well liners
Old Apr 1, 2005 | 02:07 PM
Elpelon's Avatar
Elpelon
Default Wheel Well liners
Can anyone tell me how to remove the wheel well liners and how difficult is it? I read some posts that when insulation is added some had difficulty getting all the screws back in. Would longer screws help? I hate to take on this project but I’m tired of having my ears ring after a nice ride.
Thanks.
Old Apr 1, 2005 | 03:59 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Getting them out is soooo easy! There are like 6-8 small phillips head screws (if I remember correctly). Of course you need your wheels off to do it, but they pop right out. Back in is just as easy....not sure about longer screws with insulation under there.
Old Apr 1, 2005 | 04:44 PM
ericdwong's Avatar
ericdwong
Not phillips head, they're hex head. 7 mm IIRC (or some other strange standard size).
Old Apr 1, 2005 | 04:49 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I replaced mine last summer. It's very easy and takes about 10-15 per wheelwell.
Old Apr 1, 2005 | 04:55 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
They are Philips head on my '03.
If you line the upper part of the wheel well with Frost King or Reflectix, they may be hard to get back in. There is a piece of rubber on the top of the wheel well liner that fits tight up against the body anyway, so you probably don't need the additional insulation there.
If you leave that part off, they go back in relatively easy. Stuffing the tunnel with fiberglass insulation has no effect on putting the wheel liner back in.
Old Apr 1, 2005 | 05:26 PM
Just be careful with the part of the liner that goes inside the rocker panel in the front of the wheel well. The liner can be broken if you are not careful how much you bend it - I found out the hard way.
Old Apr 1, 2005 | 05:49 PM
Elpelon's Avatar
Elpelon
Thanks for everyones help.
Old Apr 1, 2005 | 06:21 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by Elpelon
........................................ ........................................ .......but I’m tired of having my ears ring after a nice ride.
Thanks.
That sounds like a case of Goodyear EMT tires to me.............
Those tires sure are noisy.........
BTW: The liners are easy to take out and re-install.
Old Apr 1, 2005 | 06:23 PM
sailohio's Avatar
sailohio
How do you attach the insulation? and what kind do you plan to use.
Old Apr 4, 2005 | 11:51 AM
Elpelon's Avatar
Elpelon
Everyone has been using a duct insulation material by Frost King available at Lowe's. It has a self adhesive backing that allows you to stick it on the body. Only problem is that Lowes no longer carries this product. I am looking for something similar that is not to expensive. I found a product on the home depot website but the store did not carry it.
the SKU at Lowe's was 28929
To Wheel Well liners
