Worse Advice Ever !
Old Apr 3, 2005 | 03:08 AM
MUKAK's Avatar
MUKAK
and pour some acetone tru the TB and put a match to it
Really helps the Carbon clean up for a oing free engine !!
Old Apr 3, 2005 | 03:13 AM
blackbelt's Avatar
blackbelt
That bad??? I do it all the time makes sense to me gotta get it all out!
Old Apr 3, 2005 | 03:19 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Originally Posted by Oldvetter
One person wrote in on a car do-it-yourself help column, that a person told him to run his car engine for 2 minutes with the oil drained and the oil plug removed to get every last drop of used oil out of the engine !
Needless to say, the column writers told him this was NOT adviseable, especially if he didn't want extreme excessive wear and his engine to freeze up.
One word, INCREDIBLE !
My brother-in-law (who knew nothing about carcare) once had a Maverick (remember those?). He noticed that it was running rough and so brought it over for my dad to take a look at.
When dad pulled the dipstick, there was barely any oil on it. Brother had driven 35 miles with a nearly empty crankcase to get to our house and the car still ran.
Mabye Ford built tough engines or something...
Old Apr 3, 2005 | 09:09 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I thought the best way to clean out the engine was to:
1. Drain oil
2. Fill Crankcase with Dawn diswashing detergent
3. Start engine and drive for a few miles to work it in
4. Drain Dawn out of engine
5. Break up clay bar and put in engine.
6. Run engine for 1 minute with clay bar. Remember, dont use the clay bar if you drop it on the ground.
Now, your engine should be very clean and you can use whatever oil you think does the best job.
jeff
JK of course just in case someone actually believes this. lol
Old Apr 3, 2005 | 12:25 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
They do it in TV commercials!!! At full rpm's. Why can't we?
Old Apr 3, 2005 | 12:43 PM
Darion's Avatar
Darion
Old Apr 3, 2005 | 01:01 PM
gordonb50's Avatar
gordonb50
In the 60's, a guy that owned a service station back home used to run a gallon of white gas through each vehicle he did oil changes on. Said it cleared out all the gunk. Sounded like a good story, but I'd never let him do it to mine. I couldn't imagine doing something like that (or running it without oil) on today's engines.
Old Apr 3, 2005 | 01:19 PM
boracayjohnny's Avatar
boracayjohnny
From: You should have told him it would not hit 185 if you dropped it out of the back of a C130 with 4 heffalumps inside trying to get to the Golden Corral.
there was a guy who made the forum rounds with an oil change trick. he had this new srt-4 dodge and couldn't/wouldn't figure out how to get the oil drain plug off. he decided the smartest thing to do was take the oil filter off and start the engine. he even went so far as to post his great "find" on the forum. they gave him an endless amount of shiite. the way i found out was a cross posting to another forum and it was almost to stupid to actually believe. he stopped posting soon after and the forum got many, many hits...enough to set viewer records even.
Old Apr 3, 2005 | 01:44 PM
TexasMadMan's Avatar
TexasMadMan
35 years ago I worked with a dude (he was a mechanic) that poured a can of B12 (carb cleaner??) in the crankcase before each oil change, drive it 50 miles and then change the oil. He claimed it didn't hurt anything.
Any comments of THIS practice?
Old Apr 3, 2005 | 03:49 PM
Oldvetter's Avatar
Oldvetter
There used to be an engine flush, that you ran for 15 minutes (car idling) before you changed oil. I used it once, when water (from flood) got into my 1964 Corvette. Never had a problem with that engine.
Old Apr 3, 2005 | 05:37 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Originally Posted by army2000
yea, the same numb-nut probally drives around with his tires deflated to get all the air out of his tires before he breaks them off the rim
Errrr, that's not normal practice?
Mark
Old Apr 3, 2005 | 06:15 PM
NSTG8R's Avatar
NSTG8R
what? you mean you dont?!
Old Apr 3, 2005 | 06:18 PM
  #33
NSTG8R's Avatar
NSTG8R
they'll run ... just that roughness was his engine wearing the p!ss outta itself.
Old Apr 3, 2005 | 09:20 PM
  #34
ddisd's Avatar
ddisd
that's awesome
Old Apr 3, 2005 | 10:03 PM
  #35
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Originally Posted by dbirdhouse1
Actually it came from Joe's Engine Rebuilding Service......
A recommendation that will gain them more business?
Old Apr 3, 2005 | 11:22 PM
  #36
D.K.'s Avatar
D.K.
I remember that thread. Obviously total
Old Apr 3, 2005 | 11:44 PM
  #37
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The Tappet Brothers?
To Worse Advice Ever !
Old Apr 4, 2005 | 06:05 PM
  #38
Old Apr 4, 2005 | 06:09 PM
  #39
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
I'll try it tonight, and let you guys know if it gives me more power.
Old Apr 4, 2005 | 06:45 PM
  #40
98vert6spd's Avatar
98vert6spd
wow
but seriously my grandpa continually tells me that if you have an engine thats old and needs flushed otu the best thing to do is drain it and dump2 quarts of tranny fluid in it
i always think hes full of **** but he swears by it
anyone ever here of this?
