Headlight housing
Old Apr 4, 2005 | 06:00 PM
BoYD's Avatar
BoYD
Default Headlight housing
Besides the stock bulbs being not so great...they sit behind very thick, textured, not-so-clear plastic.
Can the headlight housing be replaced with a nice clear glass or plastic? While retaining the stock pop-up style?
Old Apr 4, 2005 | 06:17 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Here you go: http://www.pfyc.com/store/merchant.m...ode=VTLIGHTING
Old Apr 4, 2005 | 07:07 PM
BoYD's Avatar
BoYD
thanks...i'm not sure this is exactly what i need. But i emailed them to get more info.
I just want to replace that gross yellowish plastic that houses the headlights. I'm hoping to find a nice clear glass piece.
Old Apr 4, 2005 | 07:45 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I believe they're faceted that way to disperse the light. Clear covers might not work so well.
Old Apr 4, 2005 | 07:52 PM
SFengineer's Avatar
SFengineer
Use dremel, cut off front. Get a sheet of 1/4 inch lexan from home depot, glue and silicon on. I agree with the previous post about the plastic being a diffuser though, you either have to have a diffuser in the headlight housing or a cover for the bulb if it's in a clear housing.
To Headlight housing
