Lock Question Needs Answered !!
Lock Cylinder Replacement - Instrument Panel (I/P Compartment Door)
Removal Procedure
-Open the I/P passenger compartment door.
-Remove the screws retaining the passenger compartment door handle.
-Remove the door handle.
-Insert the key into the door handle lock cylinder.
-Turn the key 1/4 turn clockwise (LOCK position).
-Release the lock cylinder retainer. Insert a small diameter tool into the slot on the RH side of the door handle and depress and hold the lock cylinder retainer.
-Turn the key an additional 1/4 turn clockwise.
-Pull to remove the lock cylinder.
Installation Procedure
-Insert the key into the lock cylinder.
-Insert the lock cylinder into the passenger compartment door handle. Align the lock cylinder in the same position used for removal, then push to seat fully.
-Turn the key 1/4 turn counterclockwise to secure the lock cylinder retainer.
-Turn the key an additional 1/4 turn counterclockwise and remove.
-Inspect the operation of the lock cylinder. The lock cylinder should only allow a 1/4 turn and should be securely retained in the door handle.
-Install the door handle to the passenger compartment.
-Install the passenger compartment door handle retaining screws.
-Close the passenger compartment door.
