DIC Range
Old Apr 5, 2005 | 12:13 AM
WWK888's Avatar
WWK888
Default DIC Range
Anyone else have problems with the "range" on the DIC? I fill my car up and it only reads 128 or so. It use to read about 268 on fill ups. It seems to be fluctuating all over the place. My warranty is almost up and I am debating whether or not to take it to the dealer.
Any comments would be appreciated...
Aloha,
Bill
Old Apr 5, 2005 | 12:15 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I had that happen once ... very empty tank, when I filled up ... went to normal range after a few minutes ... otherwise no help. Sorry.
Old Apr 5, 2005 | 03:24 AM
EHS's Avatar
EHS
When you fill it up -- reset the average mileage as well -- they are interlinked.
Old Apr 5, 2005 | 07:14 AM
Old Apr 5, 2005 | 08:31 AM
c5rulz's Avatar
c5rulz
After resetting average mileage switch back to range. It will got from low fuel (when stationary) and start climbing fast as you get out on the road. Mine will then climb out to about 500 mile range.
Old Apr 5, 2005 | 09:05 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Is your gas gauge acting OK? There have been lots of problems in that area..
Aloha,
Bill
Old Apr 5, 2005 | 11:55 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Apr 5, 2005 | 12:27 PM
3RD-INF's Avatar
3RD-INF
If you have a full gas tank. Get up to about 60 mph, and reset the gas mileage on your D.I.C. It should read about 28 to 33 mpg. Then scroll down to your range setting. It will read anywhere from 375 to 530 miles.
Mine will read about 525. If not,then you need to have some work done.
Old Apr 5, 2005 | 03:40 PM
WWK888's Avatar
WWK888
Thanks for all the replies. I always reset everything on every fill up. I have the same routine that I do everytime that is why I am concerned that it is fluctuating. Looks like I will be going to the dealer...keeping my fingers crossed they dont screw anything up.
Aloha,
Bill
Old Apr 5, 2005 | 04:01 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Maybe you should print this and take it with you?
http://forums.corvetteforum.com/show....php?t=1055870
Old Apr 5, 2005 | 05:25 PM
WWK888's Avatar
WWK888
Thanks for the link. So far my gas gauge is working properly, just the "range" seems to be out of whack. Maybe they are related, not sure.
Old Apr 6, 2005 | 04:41 AM
WWK888's Avatar
WWK888
Short update...went for an extended drive today and it seems to be working properly again. I am wondering if maybe my battery was low and causing the problem. I am going to hold off going to the dealer for now...thanks again for the replies.
To DIC Range
