Disconnected battery now keyless entry remote does not work?
Old Apr 5, 2005 | 04:59 PM
pattymelt3605's Avatar
pattymelt3605
Default Disconnected battery now keyless entry remote does not work?
Last night I disconnected my battery on my 99 Corvette and now the keyless entry remote does not work? Is this coincidence or did my battery in the remote die?
Old Apr 5, 2005 | 05:00 PM
RedRider98's Avatar
RedRider98
My 98 did the same thing when I unhooked the battery. You have to reprogram it. Try holding the loc+unlock down for about 10 seconds. The horn should honk. If it doesn't, go through the reprogram on you DIC.
Old Apr 5, 2005 | 05:02 PM
Just retrain the fobs and see if that gets them to working again. Should be all it takes.
Old Apr 5, 2005 | 05:05 PM
BlackC5Vette's Avatar
BlackC5Vette
This should work, if it doesn't PM me and I'll walk you through it!
Old Apr 5, 2005 | 05:13 PM
Dave1998's Avatar
Dave1998
It happens to most of us
Old Apr 5, 2005 | 05:27 PM
pattymelt3605
Thanks guys, will try after I get off work.
Old Apr 6, 2005 | 12:33 AM
Admiral Fairway's Avatar
Admiral Fairway
You will more than likely have to unlock your radio also.
Old Apr 6, 2005 | 12:41 AM
pattymelt3605
Just had to hold the buttons and it worked. Thanks guys!
Old May 1, 2014 | 12:59 AM
kujo1963's Avatar
kujo1963
ou
i put new headers on so i disconected the battery did the lock and unlock for 10sec seem to work but now the unlock and horn intermintently goes off any thoughts
Old May 1, 2014 | 06:35 AM
65GGvert's Avatar
65GGvert
Originally Posted by kujo1963
ou
Your's is a different problem. You didn't say, but your profile says you have a 98. That has a passive remote system, so at least one of your fobs must be close enough to the car to activate the lock and security system. Try turning off the slide switch on all fobs you have and see if it still happens. Your best bet for help is to start a new thread, STATE the YEAR of your car and describe the problem.
Old May 1, 2014 | 12:41 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
ou
Had the same issue when I changed the remote battery a couple of weeks ago. After two or three normal lock/unlock sesssions, it stopped and stated functioning normally. I did cycle the passive/on/off a couple of times as well just to see if that would help. I really think after a day or so, it will be fine. Zuti
Old May 25, 2014 | 12:56 AM
GreggHammer's Avatar
GreggHammer
This info saved me a trip to the dealer and a sleepless night. Thanks for the info!
To Disconnected battery now keyless entry remote does not work?
