Need Advice: Moving
Old Apr 6, 2005 | 12:10 PM
wore's Avatar
wore
Default Need Advice: Moving
Moving from FL to NC. Rented moving truck and car carrier. I have not used a car carrier with corvette. Anything I should look out for? Any info would be great. Thanks
Old Apr 6, 2005 | 12:55 PM
AEmedic's Avatar
AEmedic
This winter I moved from WA to CA and I had some concerns with clearance so I got the ramps so that they were on a driveway incline such that the ramps were almost level with the trailer and "backed" the vette on the car hauler. It worked great no clearance problems at all.
Old Apr 6, 2005 | 01:00 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I'm sure you've already considered this, but, if it were me, I'd just pack all the belongings into the truck and drive the Vette. Make it a pleasure trip as far as possible and arrive fresh at your new destination ready to unpack all those boxes! Then you wouldn't have to worry about leaving the Corvette in the hands of strangers.
Old Apr 6, 2005 | 01:12 PM
Ghost Vette's Avatar
Ghost Vette
Thats a short drive and some great sites to see along a fun drive.
Old Apr 6, 2005 | 06:59 PM
wore's Avatar
wore
Default Thanks
I am going to drive the truck and pull the trailer. I will find an incline to get the car on. Thanks for input.
Old Apr 6, 2005 | 08:54 PM
PaceThis's Avatar
PaceThis
Just make sure to get the full trailer (not the dolly) and you won't have any problems. I'd check your tie downs after 30 miles and again every gas fill up (more often if they seem to be loosening.
Old Apr 6, 2005 | 10:01 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
I'm with the other's on this one. Since it'll be an 8-11 hour drive (depending on where to where) I'd drive the car. No hassles, no worries cause if you're renting a Uhaul trailer, they are cumbersome, heavy, hard to get the car on and off and basically Uhaul stuff is worn out crap. (at least it has been for me everytime I've used it)
Good luck and if no else has mentioned it, WELCOME to NC. If you're moving around the Charlotte area and need help or info, PM me.
Mark
To Need Advice: Moving
