Help! E-Brake Scraping?
Old Apr 6, 2005 | 03:35 PM
Nobigspoilerz's Avatar
Nobigspoilerz
Default Help! E-Brake Scraping?
This afternoon I was backing down the driveway and pulled up on the E-Brake in an attempt to adjust it a bit and it grabbed fine. I released it and after cruising for a while, lowered the windows and now I hear a scrape-scrape-scrape that sounds to be coming from both sides of the rear on every wheel revolution. Any ideas? Car is an '03 Z06. Thanks in advance.
Old Apr 6, 2005 | 04:24 PM
Nobigspoilerz
TTT
Old Apr 6, 2005 | 04:28 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I never use mine, but it sounds as if you have to pull the rotor and adjust it.
Havn't done it but there was a thread on it not to long ago.
Good luck and waves.
Old Apr 6, 2005 | 04:36 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Good chance that the parking brake lining retaining spring popped out or broke and is scraping the rotor
Old Apr 6, 2005 | 04:38 PM
Nobigspoilerz
C5 Tech,
Thanks for the reply. Is that a difficult repair and is it only on one rear wheel? If so, which one?
Old Apr 6, 2005 | 10:47 PM
Nobigspoilerz
FWIW, I took off the back wheels and rotors and all was well. Know what it was? I didn't torque the front lugs last week (yep - cleaning the wheel wells) and I had loose nuts. (Stop it!) The noise was coming from the spacer between the wheel and the rotor. Thank the Lord that I didn't go for a high speed run! There but by the Grace of God go I...
Old Apr 6, 2005 | 10:55 PM
Admiral Fairway's Avatar
Admiral Fairway
Good thing you found it before it came off, or you would have been the founding member of the flying tire club.
Old Apr 6, 2005 | 11:16 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Old Apr 7, 2005 | 02:42 AM
3RD-INF's Avatar
3RD-INF
Nice detective work.
To Help! E-Brake Scraping?
