just had car dynoed
Old Apr 13, 2005 | 12:07 AM
F.J.B.'s Avatar
F.J.B.
From: Vette Doctors Performance RX450 - 466RWHP !!!
Originally Posted by lvvette777
You should be really excited considering someone on this forum was bragging how he got 350 RWHP and "only" had to spend $5000 to get it.
If your referring to me...then yes....his numbers are outrageous for whats not yet done to the engine or exhaust!!!!!!!!
Old Apr 13, 2005 | 12:08 AM
CUlookin's Avatar
CUlookin
those are good numbers! congrats!
Old Apr 13, 2005 | 12:14 AM
nwdanner's Avatar
nwdanner
Originally Posted by steves red vette
i have a 2001 vette. auto 273 gears, just had it dynoed all it has is blackwing filter and ti exhaust . it was 320 is that good or fair. thanks steve.
So, is that 320 a measurement of rear-wheel HP or rear-wheel TQ? What dyno? Post the chart!
Old Apr 13, 2005 | 07:55 AM
blazeone's Avatar
blazeone
I would guess that the 320rwhp is probably actual i.e. uncorrected and not SAE i.e. corrected.
Old Apr 13, 2005 | 08:03 AM
jjk2509's Avatar
jjk2509
Originally Posted by DRKNGHT
What kind of dyno was it? Those are very stout numbers!
Old Apr 13, 2005 | 11:45 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Originally Posted by jjk2509
Dynos are the bain of the uninformed enthusiast. These #'s get tossed out to the owners and they believe it. Use the proper correction factors and you're ok. Dial in 1000 ft below sea level and zero humidity and you'll "produce" more RWHP than the engine is rated by the factory at the crank. Drives me nuts.
Old Apr 13, 2005 | 11:58 AM
JoshVette's Avatar
JoshVette
What exhaust do you have on it? what's "ti" exhaust??
nice numbers.
Old Apr 13, 2005 | 12:31 PM
red97vette's Avatar
red97vette
killer numbers!
Old Apr 13, 2005 | 12:33 PM
charliesc5's Avatar
charliesc5
Old Apr 13, 2005 | 12:56 PM
wps5's Avatar
wps5
Did a DynoRun this past weekend on my 2000 Vert Auto Dynorun on Sat.
Pull One SAE Max Power = 330.7 SAE Max Torque = 336.4
Did a tune because it was running really rich and at 5800 RPM there was a 30hp drop off
Pull Two SAE Max Power = 333.6 SAE Max Torque = 338.6
and the 30hp drop off at 5800 RPM was gone
I have the following mods: Corsa Indy Pace Car exhaust, X pipe, no cats, 160 Thermostat, coolant bypass, Vortex intake
I think if I add the hood seal those numbers should go up
Old Apr 13, 2005 | 01:01 PM
blazeone's Avatar
blazeone
nice numbers.
"ti" stands for titanium Z06 catback.
Old Apr 13, 2005 | 01:58 PM
nwdanner's Avatar
nwdanner
Amazing. My measly '02 M6 peaked at 328rwhp/344rwtq (SAE) with Quad Borla Stingers and a Blackwing intake (up from 312/334 bone stock). I'm surprised that your car, being an A4 and similarly modded, pulled even higher numbers.
The hood seal will add about 15hp.
Isn't dyno-racing fun?
Old Apr 13, 2005 | 03:53 PM
  #33
Ruler89's Avatar
Ruler89
I'm only pulling 323hp/343tq - 2004 A4 2.73 w/ Halltech Stinger, LGM LTs, Magnaflow exhaust & dyno tune. Either you have got a perfectly tuned motor or the dyno is off.
Old Apr 13, 2005 | 05:07 PM
  #34
Ron H's Avatar
Ron H
Does anyone that has used MTI in Houston have a concern that they may be inflating their dyno numbers?
I guess a few horses can come from us being at sea level.
Old Apr 13, 2005 | 05:16 PM
  #35
wps5's Avatar
wps5
Well Tampa Fl is at sea level can't get much flatter than Florida. Not sure why you would think the Dyno is not right because I was pulling higher numbersthen you. You didn't mention if you have cats or an xpipe. I know not having the cats is good for a couple of HP's along with the xpipe. My A4 is also has 3.14 gears. Anyway I am a happy camper :-)
BTW, there were a bunch of guys with Z06's there as well. Some of these cars were amazing, one pulled 511, but I guess with 30k in mods anyone can do that :-). I was one of the only non z06's there and my numbers were much smaller then theirs. I was just happy that I was pulling better then a stock Z06
Old Apr 13, 2005 | 05:24 PM
  #36
Doubletap's Avatar
Doubletap
St. Jude Donor '08-'09-'12
3.14 gears are those custom?
Nice numbers now take it to the track, and report back to us.
Old Apr 13, 2005 | 05:38 PM
  #37
Doubletap's Avatar
Doubletap
333 Is better then a stock Z06?
