window question
Old Apr 10, 2005 | 03:45 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Default window question
I just took the cover off the vette washed it and was about to go for alittle ride but when i pushed the button for the passager side window it did not go down.I can here a click in the door like it wants to go down but i dosent.Anybody have and suggestions why this happned?It was to warm out to drive with just with the drivers window down.....Thank you charlene
Old Apr 10, 2005 | 03:54 PM
pewterwest99's Avatar
pewterwest99
Default window reply
When I bought my '99 Coupe about 5 months ago, it had the same problem. I'm not sure what caused this. I took it into the dealer and the replaced the passenger window regulator/motor assembly the bill was $575.90, But it has been working like a dream ever since.
Regulator part #1 10344132
Best of Luck
Old Apr 10, 2005 | 04:18 PM
charlene's Avatar
charlene
[QUOTE=pewterwest99]When I bought my '99 Coupe about 5 months ago, it had the same problem. I'm not sure what caused this. I took it into the dealer and the replaced the passenger window regulator/motor assembly the bill was $575.90, But it has been working like a dream ever since.
Best of Luck[/QUOT Thanks my car is still under warranty thank goodness so i am sure if that is the problem it will be fixed for free.
Old Apr 10, 2005 | 05:23 PM
'99 Feather's Avatar
'99 Feather
This has happened to my '99 several times. I took it to the dealer when it was under warranty and they replaced the regulator. But it ended up happening again. Now I just shut the door a little harder than normal after pushing the auto down button. This usually free's it up.
I have heard that the window regulator gets stuck due to infrequent use. So now I try to make sure I cycle the passenger window whenever I get in now to keep it freed up. In the past, the passenger window did not get used as often as the driver's window since I am usually the only one driving it. I haven't had the problem since I started this practice.
Jeff
Old Apr 11, 2005 | 12:33 AM
charlene's Avatar
charlene
Jeff
It worked fine till i coverd it up for the winter.I will go down in the garage and try pushing the window button and shutting the door harder and see what happnes.Well i tried and the darn thing still dosent work so i will call the dealership i go to and make an appointment to take it in....Thanks anyway jeff....
To window question
