CD Player Question
Old Apr 10, 2005 | 11:49 PM
1253C5's Avatar
1253C5
Default CD Player Question
Can someone tell me what a GM Delco "MONSOON" CD player is? I have never herd of a moodel called Monsoon.
Old Apr 11, 2005 | 12:30 AM
Lithium's Avatar
Lithium
It was the "nice" 6 speaker system in the F-body cars. I don't believe it was ever put stock in a vette, but I could be wrong.
--Marc
Old Apr 11, 2005 | 12:39 AM
vetty's Avatar
vetty
The monsoon in the f bodies is just like the bose in the vettes.. same thing different names!
Old Apr 11, 2005 | 10:34 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It was part of the non-bose, F-body 500 watt stock system. It was an OK system, I had 1 in my Z.
Old Apr 11, 2005 | 10:47 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I'ver got one in my 03 Grand Am - I agree with the rating of all right - not spectacular by any means.
Old Apr 11, 2005 | 10:53 AM
sinjin smith's Avatar
sinjin smith
Does anyone else feel the Bose system in the C5 is not very good? While listening to the radio, I've got the bass turned to max and very little bass is heard and overall sound quality is just not what I'd expect from a Bose system. Feel the same way? Or is my system off?
Old Apr 11, 2005 | 11:07 AM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Blose has always been known as a mid range - ear splitter. It is not just you...
Old Apr 11, 2005 | 11:17 AM
screw991le's Avatar
screw991le
As the saying goes.
A entry level aftermarket system is better than a premium stock system.
This is true in every sense but probally not in the Nacimici (sp) systems found in the $100k cars
Old Apr 11, 2005 | 11:21 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
The factory radio does not compare to anything aftermarket. However, I found it better to keep the treb, base, balance and fade neutral in the middle and use the preset settings, I like the jazz setting the best, it works well with most music types. Also if I turn the volume up past 3/4 I notice the highs and lows will start to wash out and get distorted.
Old Apr 11, 2005 | 11:39 AM
TexasMadMan's Avatar
TexasMadMan
No highs no lows means it must be Bose.
To CD Player Question
