Exhaust install
Old Apr 11, 2005 | 09:34 AM
jpc0011's Avatar
jpc0011
Default Exhaust install
Newbie - Received shipment of Corsa cat back and x pipe. Was told by dealer can take 4 hrs to install. Is this accurrate? Seems like alot of time based on all threads I have read??
Old Apr 11, 2005 | 09:44 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Gotta call on that one. should not take a good mechanic more than 30 min to an hour maybe at the max. Even doing it on jack-stands in a driveway would not take 4 hours. Mabye if you were talking complete exhaust, including headers.
Check somewhere else you are gettin shafted there.
Old Apr 11, 2005 | 09:47 AM
Thunder7's Avatar
Thunder7
WHAT? You have got to be kidding. I did my own, and the hardest thing was getting it up in the air to get the stock exhaust off. I think total time was a little over an hour. And that was about 20-30 minutes of mucking with getting the pipes aligned.
Old Apr 11, 2005 | 10:00 AM
jpc0011's Avatar
jpc0011
Thanks. I appreciate it. Thank God for this forum. It is absolutely invaluable especially for new Vet owners. I am only installing catback and xpipe.
Old Apr 11, 2005 | 10:03 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
No Way. I did my own. Took about 45 mins. to figure how to lift it to the right height to remove the stock exhaust. Once the old one was out about 30 mins or less to add the new one (that includes alignment).
If I had a lift total time 30 - 45 mins....
Old Apr 11, 2005 | 10:04 AM
Thunder7's Avatar
Thunder7
Well, with an X-Pipe that will take a little more as there is some cutting off of the H-Pipe and then getting the X-Pipe all good to go. Would add a bit more time. But still, 4 hours seems over kill.
Old Apr 11, 2005 | 10:08 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
FWIW If you have access to a wall or loading dock...just back your car onto ramps at the EDGE of the wall!!! It is a piece of cake, and alot safer than the jackstand with wood blocks and all the rest of the cribbing to get your car high enough!!!!
Old Apr 11, 2005 | 12:46 PM
Mr. C's 5's Avatar
Mr. C's 5
Be careful of who you get to do this. Dealers might install a lot of exhaust systems (which shouldn't take more than an hour on a lift), but as prevoiusly mentioned, X pipes take some time and care. The cuts have to be measured and then a chain cutter is used to make a square cut. If they don't do it right, it could leak and requre welding to patch it. If you have them do it, ask them how it will be done. - C.
Old Apr 14, 2005 | 01:36 PM
jpc0011's Avatar
jpc0011
Well, had the exhaust installed today w/ x pipe. Total install time was 1 hr 45 mins. Tips are perfectly aligned and it sounds Grrrrrreat!!!! I wont name the dealer who told me 3-4 hours, but lets just say they come very well recommended by local Corvette Club. Anyway I am very happy, started a relationship w/ a solid shop who will get more of my business. *** I tried to use the dealer??? Shame on them
Old Apr 14, 2005 | 02:16 PM
speedfreek155's Avatar
speedfreek155
Took me 1.5 hrs on a lift to install X-pipe and Tubi cat backs . Had to unbolt rear sway bar to get pipes over rear , secondary crossover tube on this system .
Old Apr 14, 2005 | 02:41 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
I was just about to post and saw you already have them on. That's total the dealing was feeding you about 4 hours. I was going to recommend going elsewhere and you did, glad you got it done.
I'd be very leary of that dealership in the future.
Old Apr 14, 2005 | 03:07 PM
2003vert's Avatar
2003vert
Dealer does most of my work also, charged 80.00 for the cat back install. There are good, bad, and REALLY UGLY!!! dealers. sounds like you found a good one.
Old Apr 14, 2005 | 05:31 PM
No way it should take 4 hours. I took my car into a local muffler shop for the x-pipe and cat back install. Took them about 1.5 hours and cost me $80.
Old Apr 14, 2005 | 07:03 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
if you where in new england i do these for a case i'll even let you run the lift
Old Apr 14, 2005 | 08:08 PM
Dark-Knight's Avatar
Dark-Knight
30 minutes on a lift... ... guy is trying to rip you off.
Old Apr 14, 2005 | 08:54 PM
SteveDoten's Avatar
SteveDoten
if imported beer is considered a ripoff, i guess you got me
Old Apr 14, 2005 | 09:00 PM
John Cullen's Avatar
John Cullen
Hi DIP51,
Thanks for the tips everything worked out great.
John
Old Apr 14, 2005 | 09:43 PM
TkitPlz's Avatar
TkitPlz
I just had a Corsa Indy exhaust, Corsa x-pipe, Donaldson Blackwing, CAGS eliminator, GM bra and exhaust plate installed and it took my dealer about 1.5 hrs. to do it all. Total install labor was $98. Dan
To Exhaust install
