would it be safe to...
Old Apr 14, 2005 | 02:03 PM
FallenWhun's Avatar
FallenWhun
Default would it be safe to...
install my enhancer plate using industrial strength velcro instead of the supplied double stick tape?
I figured it would make cleaning easier, but it i'm thinking that it might fly off @ one point or another.
Old Apr 14, 2005 | 02:06 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I used the double sided tape 4 years ago, and it is still on real strong.
Once it is stuck on, it will always be clean under the plate.
Old Apr 14, 2005 | 02:31 PM
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
I wouldnt use the Velcro. I know that the industrial stuff is pretty strong but I still wouldnt trust it.
Old Apr 14, 2005 | 02:47 PM
DaBoz's Avatar
DaBoz
Mines been on for nearly a year with heavy duty velcro.... very secure!
Old Apr 14, 2005 | 02:48 PM
EHS's Avatar
EHS
I know double stick tape works. And has, for five years.
Old Apr 14, 2005 | 03:21 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Industrial strength all the way! Very secure and, if you don't install it correctly the first time, you can always start over again until perfection is achieved. Just my $0.02.
Old Apr 14, 2005 | 04:22 PM
jrose7004's Avatar
jrose7004
Mine has been on for right at a year and the double sided tape is still holding strong!
Old Apr 14, 2005 | 04:29 PM
PepFontana's Avatar
PepFontana
Velcro for me.
Old Apr 14, 2005 | 05:01 PM
xwing's Avatar
xwing
I used velcro to hold my front plate cover on. (That way I can take it off if necessary, b/c the plate is underneath it.) In 3 years, the velcro hasn't failed me yet.
Old Apr 14, 2005 | 05:06 PM
ALLEGRO's Avatar
ALLEGRO
It will work just fine!
...and it will keep you off your back to clean the darn thing!
Old Apr 14, 2005 | 05:09 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
In my time on the forum I have only heard of 1 exhaust plate being lost and that person did not clean the area prior to installation
Old Apr 14, 2005 | 05:11 PM
Yes, you could use velcro to install the plate. I chose to go with the supplied double sided tape since I didn't feel I would have to worry about cleaning under the plate once it was stuck on. If anyone wants to look under the plate for dirt, let them try and get that thing loose.
Old Apr 14, 2005 | 05:53 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
10 months for me...
To would it be safe to...
