Front Air Dam
Old Apr 14, 2005 | 03:36 PM
JLA's Avatar
JLA
Default Front Air Dam
If that's what it's called. The black rubber/plastic thing that scrapes. I did a search and found a post that mentioned gmpartsdirect.com. Couldn't find it there. Can someone point me in the right direction?
Old Apr 14, 2005 | 03:44 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
are you looking for a part number, source for a new one or both?
Old Apr 14, 2005 | 03:46 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
look here...
http://temp.corvetteforum.net/c5/ken...rtspage6.shtml
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I'll take both.....I know mine can't last much longer.......
Old Apr 14, 2005 | 03:47 PM
X-ZZ4's Avatar
X-ZZ4
Originally Posted by Grumpy
Sweet.....thanks Grumpy!
Old Apr 14, 2005 | 03:51 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
and for part numbers check this link out
Old Apr 14, 2005 | 04:11 PM
JLA's Avatar
JLA
Mucho thank you!!
Old Apr 14, 2005 | 05:23 PM
You may want to try either Fred Beans Pontiac or Fichtner Chevy for the parts also. Good prices there too.
Old Apr 14, 2005 | 07:37 PM
EHS's Avatar
EHS
Old Apr 14, 2005 | 07:46 PM
JLA's Avatar
JLA
O.K. I downloaded the massive pdf. parts file. Go easy on me, but after looking thru it, I'm still not sure of a part number. Is the air dam thing 3 pc's? Right, Left & Center? Is it even called "air dam"?
Old Apr 14, 2005 | 07:51 PM
EHS's Avatar
EHS
Would it be OK if you just called Bob at Fichtner, and let him worry about getting you the correct piece?
His price will probably be about the best anyway.
No sense in scratching your head the way you scraped the air dam.
Old Apr 14, 2005 | 07:56 PM
Dark-Knight's Avatar
Dark-Knight
I trimmed mine an inch so it would not scrape all the time after car was lowered.
To Front Air Dam
