2000 HUD to Low
Old Apr 17, 2005 | 10:31 AM
mwbmd11's Avatar
mwbmd11
Default 2000 HUD to Low
I just bought a 2000 with the HUD. However, To see the display with it all the way up my head has to touch the roof. Does anyone know if this can be adjusted and how?
Old Apr 17, 2005 | 10:38 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The "display" right under the on-brightness lever. That moves the display up and down. If I remember correctly, down is up and up is down. I could be wrong, I set mine when I got her and never touched it since.
Old Apr 17, 2005 | 10:41 AM
T's's Avatar
T's
Cruise-In VII Veteran
same here!
Old Apr 17, 2005 | 02:26 PM
mwbmd11's Avatar
mwbmd11
I found the buttons that move it up and down, but as high as it will go is still way to low.
Old Apr 17, 2005 | 02:35 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
damn ...just how big an ol boy are you??
Old Apr 17, 2005 | 02:55 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
I was going to say the same thing, but I hesitated. I am 6'2'' and have absolutely no trouble seeing the HUD. Also, how high is your seat? Try lowering your seat in combination with using the "display" button. This should help.
Old Apr 17, 2005 | 03:11 PM
Pipes's Avatar
Pipes
Just a thought, if it's your steering wheel that's interfering with the hud, might try lowering the wheel.
Old Apr 17, 2005 | 03:54 PM
BiggieBoy's Avatar
BiggieBoy
Maybe the mirror adjustment inside the projector is defective. If so, you'll need a new projector....
Old Apr 17, 2005 | 06:30 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Im 6'2" and I have the HUD as high as it will go. Its a little low for me. also the stering wheel as I make it just right, I cant see the DIC.
Oh well, its still fun to drive
Old Apr 17, 2005 | 06:34 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
St. Jude Donor '05-'06
I am close to 6'6" and I have not problem with the HUD at all.
Old Apr 17, 2005 | 06:40 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default 5'8" w/HUD
I'm 5'8" and I can see mine just fine. Mybe you can change the angle on the projector.
Bob K.
Old Apr 18, 2005 | 01:05 PM
That's the way to do it. The HUD display has a good range of adjustment available.
Old Apr 18, 2005 | 01:43 PM
TANGLVR's Avatar
TANGLVR
perhaps one of the mounting screws is loose causing it to droop and cast the image lower than usual? Just a thought.
MM
To 2000 HUD to Low
