Traction Competition Mode
Old Apr 17, 2005 | 10:54 PM
Melodie's Avatar
Melodie
Default Traction Competition Mode
When autocrossing today, a friend of mine told me that I should be able to press on the traction control and that it should go into a competition mode. Is this an option just on some cars? We pushed it and didn't notice it doing anything.
Old Apr 17, 2005 | 11:04 PM
JameyTurner's Avatar
JameyTurner
Too Much Fun
hold it down for about 5 seconds and it will show "Competitive Mode" in DIC
Old Apr 17, 2005 | 11:26 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes, it an option on some cars. What year is your car? Active handling is needed.
Old Apr 17, 2005 | 11:35 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Depends on the year of car.
When autocrossing just turn it all off.
Old Apr 17, 2005 | 11:39 PM
GrayC5's Avatar
GrayC5
The Competitive Driving Mode is available only if your car is equiped with Active Handling. The Active Handling System, RPO JL4, debuted as an option on the 1998 Corvette and became standard equipment in model year 2001. Here are a few links that will tell you more about Active Handling along with the Competitive Driving Mode and how it works:
Corvette Active Handling System Debuts
Old Apr 17, 2005 | 11:41 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I have to hold mine down for about 8 seconds. But the early years also had to be stopped to do it. I think in 2002 they changed that so you can do while rolling.
Old Apr 17, 2005 | 11:58 PM
Melodie's Avatar
Melodie
My car is 1998. I don't think it has active handling. I think it is traction control only. I know that the active handling gives you a couple of settings and I always believed my traction control just goes on and off.
Old Apr 18, 2005 | 12:00 AM
GrayC5's Avatar
GrayC5
True, cars equipped with 1st Generation Active Handling have to be brought to a complete stop in order to enable the Competitive Mode. The 2nd Generation Active Handling was introduced in model year 2001 and with it the Competitive Mode can be enabled while the car is moving:
Model Year 2001 Press Release - More Agility...
Old Apr 18, 2005 | 12:01 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
I believe you are SOL. Just turn it off anyway, it just gets in the way when you are trying to spin through the infield.
Old Apr 18, 2005 | 12:03 AM
uknowme2good's Avatar
uknowme2good
i have a 1998 conv. put the car in park foot off the brake...press and hold down the button for 5-10 sec...it should pop up...if not you dont have it...
Old Apr 18, 2005 | 12:10 AM
GrayC5's Avatar
GrayC5
If your car is equipped with Active Handling, the words "Active Handling" will appear above your button and your cars RPO label will show J4L which is the RPO Code for Active Handling.
Old Apr 18, 2005 | 01:20 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I didn't know that about the 2nd Gen. Anyway to mod a 1st Gen car to behave like a 2nd???
Old Apr 18, 2005 | 01:40 AM
GrayC5's Avatar
GrayC5
Good question, but I don't have an answer as to what it would take.
Old Apr 19, 2005 | 12:31 AM
Melodie's Avatar
Melodie
Default Awesome
AS USUAL-Thanks! You guys are awesome!
To Traction Competition Mode
