fog light replacement
Old Apr 18, 2005 | 12:08 AM
Aggie99's Avatar
Aggie99
Default fog light replacement
Hey guys,
I just noticed one of my fog lights had gone out. Can some one send me a link on how to replace it, and what size of a bulb I need to replace it.
Thanks.
Old Apr 18, 2005 | 12:24 AM
uknowme2good's Avatar
uknowme2good
Default link? u dont need no stinking link
open ur hook....look down next to ur to the head lamp u will the fog lamp socket....if u have fat arms u will have to remove the head lamp bezel....either way u can reach the fog lamp socket with ur hands....the socket will turn to release it...replace the bulb...dont touch the new bulb with ur hands.....
Old Apr 18, 2005 | 11:02 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Apr 18, 2005 | 11:06 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Fat arms stink for this. I had to get my wife to do it even when I took the headlight cover off.
Also think of buying the 885s instead of stock - they are much brighter. Plus you should adjust your Fog Lights up since they come from the factory too low.
Old Apr 19, 2005 | 08:51 AM
Aggie99's Avatar
Aggie99
Thanks for the help. $7 and an hour later she's good as new.
Old Apr 19, 2005 | 08:52 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
an hour??? whatya do , take a nap??
Old Apr 19, 2005 | 03:34 PM
screw991le's Avatar
screw991le
Make sure you aim the fog lights, it makes a big difference.
Old Apr 19, 2005 | 04:18 PM
Aggie99's Avatar
Aggie99
I have a tendency to try all the difficult routes first for some reason. After realizing it was a two second job.
Old Apr 19, 2005 | 10:16 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
a HUGE difference, a must
Old Apr 19, 2005 | 10:40 PM
coast7's Avatar
coast7
Haven't aimed them yet...are there trim screws on the fog light housing? Are the screws accessible from the outside (front of car)...or inside (from under car or via headlight bezel)? Do you aim them at your garage door at night to adjust?
Old Apr 20, 2005 | 07:35 AM
screw991le's Avatar
screw991le
http://www.c5forum.com/diy/fog_lamps.php
Old Apr 20, 2005 | 06:28 PM
coast7's Avatar
coast7
screw991|e,
Thanks for the link!
Old Apr 21, 2005 | 05:24 AM
AMGPilot's Avatar
AMGPilot
Aggie99,
I know you have already replaced the bulb but if you are interested in the best performing Halogen bulbs you can get for the Corvette then I recommend getting SYLVANIA SilverStar Halogen bulbs.
I bought them at O'Reilly Auto Parts.
The SilverStar fog light replacement is: 893ST
I replaced all of the bulbs in my C5 with SilverStars and it made a HUGE difference
To fog light replacement
