Oil Change?
Old Apr 19, 2005 | 01:30 PM
jpc0011's Avatar
jpc0011
Default Oil Change?
MY 01 coupe has 65% oil life remaining. I have now owned it for 1 year.
Do I need to change the oil? Only put 3k miles in 1 year time. Obviously I need to drive it more but would like to know if oil change is needed.
Old Apr 19, 2005 | 01:33 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I would change the oil just because of the duration if nothing else. Course, I change mine at 65% anyway, but condensation will build up in there.
Old Apr 19, 2005 | 02:11 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I found change it if it has been more than 12 months, reguardless of what the DIC says.
Old Apr 19, 2005 | 02:13 PM
SilverRoadster00's Avatar
SilverRoadster00
I figure I have to change it at least once a year. I only put 2K on her last year, but changed before storage anyway.
Old Apr 19, 2005 | 02:17 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
From the 04 OM (it is amazing the information it contains):
When to Change Engine Oil
(GM Oil Life System)
Your vehicle has a computer that lets you know when to
change your engine oil and filter. This is based on
engine revolutions and engine temperature, and not on
mileage. Based on driving conditions, the mileage at
which an oil change will be indicated can vary
considerably. For the oil life system to work properly,
you must reset the system every time the oil is changed.
When the system has calculated that oil life has been
diminished, it will indicate that an oil change is necessary.
A CHANGE OIL SOON message will come on. Change
your oil as soon as possible within the next two times you
stop for fuel. It is possible that, if you are driving under the
best conditions, the oil life system may not indicate that
an oil change is necessary for over a year. However, your
engine oil and filter must be changed at least once a year
and at this time the system must be reset.
Your dealer
has GM-trained service people who will perform this work
using genuine GM parts and reset the system. It is also
important to check your oil regularly and keep it at the
proper level.
If the system is ever reset accidentally, you must
change your oil at 3,000 miles (5 000 km) since your
last oil change. Remember to reset the oil life system
whenever the oil is changed.
Old Apr 19, 2005 | 07:33 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Im a 2500-3000 miles a year guy.
I change it once a year
Old Apr 19, 2005 | 07:35 PM
jrose7004's Avatar
jrose7004
I think a year is long enough!
Midwest Vette's Avatar
Midwest Vette
Old Apr 19, 2005 | 08:21 PM
C5 MANIAC's Avatar
C5 MANIAC
I would err on the side of safety and change the oil. Better to be safe than sorry.
Old Apr 19, 2005 | 08:23 PM
charliesc5's Avatar
charliesc5
changing the oil is cheap insurance
Old Apr 19, 2005 | 08:41 PM
2079's Avatar
2079
Old Apr 19, 2005 | 08:44 PM
jpc0011's Avatar
jpc0011
THanks. Will change asap
Old Apr 19, 2005 | 10:03 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I change the oil filter twice a year (every six months).
Old Apr 19, 2005 | 11:40 PM
GrayC5's Avatar
GrayC5
Change it. Your Owner's Manual and GM Service Manual say to change oil and filter when indicated by the Oil Life Minder or at least once a year, which ever occurs first.
Old Apr 19, 2005 | 11:47 PM
VetteTech81's Avatar
VetteTech81
I'd change it as the 1 year mark rule. If you were in my area, I'm offering oil changes for $50 w/ mobil 1 and AC delco filter. There is an upcharge for Amsoil...
-=Rick
To Oil Change?
