HI I`VE RECENTLY BOUGHT MY CAR.AND I WANT TO UPGRADE IT.I AM DEALING WITH A GUY WHO IS SELLING HIS LONG TUBE HEADERS AND BASSANI H-PIPE FOR $650.AND WHET`S THE DIFFERENCE BETWEEN X AND H PIPE.WHICH ONE IS BETTER.ALSO I FOUND ANOTHER LONG TUBE HEADERS FOR $450(BRAND MEW).aND ANOTHER CORSAX-PIPE $185(BRAND NEW).i DON`T KNOW WHICH ONE SHOULD I GO WITH.
NEED AN ADVICE
Note:Sorry I used caps.Won`t do that next time
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
NEED AN ADVICE
Any of those might be good bargains, but brand new long tubes for $450 sounds more like a "steal", as in hot, depending on what brand. You'd need to be more specific.
But my best advice to you is to make one more click on the "CapsLok" key. People feel as though you're yelling at them when it's all CAPS.
Welcome and congrats on the car!! Someone with good exhaust advice will stop by shortly, I'm sure. My only advice to you would be, and please no offense, but hit the caps lock button!
The X pipe supposedly flows better then the H pipe. Also if your car has that neutral "jingle", the X pipe will solve that problem, at least it did on mine.
Hi
Thanks for the quick response.Brand new long tube headers are what they call smooth fkow and made by Howe Racing co.They`re jet hot coated(i don`t know what does that mean) sterling hi glass silver silver finish.
thanks again
