Recall for column lock.
Old Apr 20, 2005 | 11:45 AM
Ghost Vette's Avatar
Ghost Vette
Default Recall for column lock.
Well after much concern about messing more up than fixing, I decided to go for the recall. Took it to Bill Heard Friday and took several hours to take care of it. Now it has no more lock.Since I was advised from the forum that the A4 is a must to do, I have to agree. I only had it to lock twice, but thats enough. Didn't want to go to Bowling Green this week and have it to lock up. So far, no problems and no codes. Oh yea, the squeak was also fixed. They had to spray the rubber booth under the hood where the colum comes through. This may be helpful for those who also are plagued with this problem.
Old Apr 20, 2005 | 11:48 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Good to get it done before you really need to
Old Apr 20, 2005 | 11:55 AM
HepcatX's Avatar
HepcatX
What years does this recall apply to?
Old Apr 20, 2005 | 11:58 AM
Ghost Vette
Mine is a 97. A friends 98 also has it on his. Not sure which other years has the recall.
Old Apr 20, 2005 | 11:59 AM
MyVetteDream
I think they got rid of the lock in 2000?
Old Apr 20, 2005 | 12:02 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
2001 and above A4's have no lock
Old Apr 20, 2005 | 12:03 PM
94legaleagle's Avatar
94legaleagle
Default Steering Lock
Just a question, and I may be premature and lacking info:
I'm rebuilding a 2001 w/ front end damage (minimal). I've got the electrical connections under the battery temporarily disconnected so I don't know if what I'm about to describe occurs when the vehicle is powered up, (or if powering up the vehicle even makes any difference). I'm basically wondering if what I'm about to describe indicates that the steering lock modification HAS already been done to my Vette:
I noticed that I am able to turn my steering wheel completely from wheel lock when turned to right to wheel lock turned to left WITHOUT the key being in the ignition, and WITHOUT the car being on. In other words, my steering column/steering wheel does not lock at all when the key is removed from the ignition.
Is this correct? Does this indicate the modification has been done so that my steering doesn't have the occassional locking problem I've heard about? Or, does this mean someone before me has "forced" the steering and broken/damaged something?
Thanks, Bill.
Old Apr 20, 2005 | 12:17 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
Sounds like your lock has been disabled or removed - you should be all set...
Thanks, Bill.
Old Apr 20, 2005 | 12:47 PM
Nice to not have to worry about that problem again.
Old Apr 20, 2005 | 03:33 PM
Conk's Avatar
Conk
My 02 M6 has locked up twice. I just shake the sh*t out of the steering wheel and it unlocks. I am installing a CLB. No recall work for me. It just reprograms so that it won't lock while driving, correct? It does nothing for the actual locking pin?
Old Apr 20, 2005 | 03:45 PM
Rou-Rou 03's Avatar
Rou-Rou 03
All the recall does for MN-6 is reflash your computer so your feul shuts off should it lock up . Also if you have had edits done by a tuner they will be lost when the dealer flashes your computer. Install an after market clb and stay away from the dealer.
Old Apr 20, 2005 | 03:48 PM
MyVetteDream
Auto's don't lock ... referring to 2001+
as it's been pointed out, after 2001 they didn't put the lock in.
Sorry 97-2000's
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Thanks, Bill.
Since it is a 2001, if it's an auto it never had a locking column. If it's a manual, then it has been bypassed most likely with a CLB.
To Recall for column lock.
