3rd Brake light back-up camera install
Old Apr 20, 2005 | 02:05 PM
OrionVettes's Avatar
OrionVettes
Default 3rd Brake light back-up camera install
Hi Guys..need help finding thread on installing back up camera in 3rd brake light from a few weeks ago. Im not sure who posted but I have decided to try this mod and need help. I tried searching but no help.
Im installing AVIC-N2 and can use help with pics.
Old Apr 20, 2005 | 02:50 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Here's a link to GB Vette's excellent instructions on installing the camera. I used these to install mine and didn't have any problems at all.
http://www.gbvette.com/camera.htm
Old Apr 20, 2005 | 02:53 PM
ericbrown97's Avatar
ericbrown97
St. Jude Donor '05
E:\Z06\GB's Vette - 2002 C5 Corvette Convertible - Halltech Installation.htm
I think you might have dropped the wrong link in....unless you have your machine open to the world for sharing your "E" drive.
Old Apr 20, 2005 | 02:57 PM
Z06-JIM's Avatar
Z06-JIM
Oupps!!! Corrected problem.
Old Apr 20, 2005 | 02:58 PM
ericbrown97
St. Jude Donor '05
Nice Car Jim!
Old Apr 20, 2005 | 02:59 PM
JoshVette's Avatar
JoshVette
You should put one like that in your headlights and drive your vette around like it's in a "Need for Speed, or Grand Tourismo" video game.....
Old Apr 20, 2005 | 03:00 PM
rickko's Avatar
rickko
I saw one installed lower than in center brake light. Done by a forum member.
A small hole was drilled in license plate. Camera lens was installed just behind it. Excellent job of installation.
In fact the hole happened to be drilled right where a numeral in plate was stamped. The numeral was dark blue so the hole was nearly invisble.
..rickko..
Old Apr 20, 2005 | 03:05 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Very cool setup Jim! I've seen you post this before and each time I want one a little more. Where does it end! Actually if it ended so would the fun!
Old Apr 20, 2005 | 03:29 PM
Z06-JIM's Avatar
Z06-JIM
Once you start, it never ends! It's a sickness that can't be cured! But like you said, the fun factor is what it's all about.
I appreciate your comments.
To 3rd Brake light back-up camera install
