Keyless entry
Old Apr 20, 2005 | 05:05 PM
LW97Vette's Avatar
LW97Vette
Default Keyless entry
Has this ever happened to anyone?
I programmed the keyless remote via the HUD. It worked according to the owners manuel. Then when I get out of the car to use it, it doesn't work. So then I try programming it from outside the car, again per the manual, and the car horn beeps signaling the remote is programmed, but again if I try to use it to lock/unlock the car immediately, it doesn't work.
Can anyone diagnose this phenomenon?
Old Apr 20, 2005 | 06:55 PM
jessejay356's Avatar
jessejay356
Do you have more then one key fob? Try a different battery? I've seen some other people with this problem... seems the code gets out of sync with the car. I think it's a bad key fob.
Old Apr 20, 2005 | 06:56 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Something's broke ...
To Keyless entry
