Convertible top issue C5
Old Apr 20, 2005 | 05:58 PM
99SilverVert's Avatar
99SilverVert
Default Convertible top issue C5
Hi all,
99 C5 owner.
My glass from the convertible top has seperated from the actual convertible top
Any ideas as to re-affix the glass?
I was givin the idea of 3M double sized tape (foam type), but will that repel water when it rains?
Old Apr 20, 2005 | 06:04 PM
MTurnbo's Avatar
MTurnbo
My son just had the same problem with his 2000 and had it repaired. They some how re-glued it. It has been about five months and seems to be holding fine. I'll have him drop you a line.
Old Apr 20, 2005 | 06:08 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
I had it happen a couple months ago too...some kind of glue was used to reattach it. This summer should be a test of that glue as I put the top up and down daily.
Old Apr 20, 2005 | 06:28 PM
99SilverVert
Thanks a lot guys for you input!
I actually did the foam 3m tape thing just now, but Id also glue it if I knew it wasnt water proof.
Is that tape waterproof?
Old Apr 20, 2005 | 08:22 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I used JB weld on mine, it's been almost a year now.
Old Apr 20, 2005 | 09:43 PM
Armadillo's Avatar
Armadillo
I think the foam will act just like a sponge and soak up water until it is full, then drip, but I can't confirm that.
Old Apr 20, 2005 | 09:46 PM
uknowme2good's Avatar
uknowme2good
buy a new top....u have the cash
Old Apr 20, 2005 | 09:52 PM
Poptops's Avatar
Poptops
I used 3M Super 77 Spray adhesive which I put into a cup and then brushed on where it was needed on both the glass and the top's surfaces. It's been good as new since then.
Old Apr 21, 2005 | 01:20 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Move to AZ, it doesn't rain here!
Old Apr 21, 2005 | 01:27 AM
GrayC5's Avatar
GrayC5
Good luck with the repairs.
Old Apr 21, 2005 | 09:14 AM
99SilverVert
Me cash, nope im broke. Id spring for the 400 for a new top/glass but i cant right now
Old Apr 27, 2005 | 07:47 PM
99SilverVert
Welps,I need the JB wels apparently. My car is getting soaked with the foam tape
How do u apply it to ensure theres a proper seal/waterproof?
Old Apr 27, 2005 | 08:38 PM
RPOZ4Z's Avatar
RPOZ4Z
first make sure you mix enough to do the job, I used a small ziplock bag and cut one corner off and squeezed it into the opening between the window and the top (my window didn't totally seperate from the top, just the right side), then I used a large towel on the inside to support the window, and another large towel with plastic under it to hold the outside lip of the cloth top onto the glass.
it looks perfect now.
Old Apr 27, 2005 | 10:15 PM
99SilverVert
My top has this rubber like surface on it, along the whole inside part. Will i need to remove it?
According to JB Weld:
Q: Is there anything that J-B Weld WON'T bond to?
A: J-B Weld will not adhere to, or bond well to:
Any flexible rubber surface
Leather
Vinyl
Canvass
Polypropylene plastic
Polyethylene plastic
It will still work ?
To Convertible top issue C5
