Will bigger wheels/tires offset speedometer?
The overall diameter of the Michelin 265/35/18 is actually .3" smaller than the Goodyear (stock) 245/45/17.
The overall diameter of the Michelin 295/35/18 is actually .5" smaller than the Goodyear 275/40/18.
This would obviously cause a minimal change in the accuracy of the speedo but I dont think it would be enough to make much of a difference. If it really bothered you, you could have someone go in and reprogram the new tire sizes into the computer to recalibrate the speedo.
Also, in regards to your second question about running 18's all the way around, you should be fine. As long as your front and rear tires have a decent difference in their overall diameter you should be fine. The Michelin sizes you mentioned should be fine.
Good luck
at sane speed, it's within 1mph, so it's not really an issue. Speedometers are only accurate to within a few mph, so you shouldn't even notice it.
Good luck
Go to this web site and you can calculate MPH based on tire size, etc.
Fred
