HUD question
Old Apr 20, 2005 | 10:59 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Default HUD question
It seems about half of the C5s with HUD I get into always has the oil gauge showing. I'll switch it to gas or engine temp, turn it off and restart it and it shows oil!? What am I missing?
Old Apr 20, 2005 | 11:38 PM
Crockettman's Avatar
Crockettman
I've never had anything like that happen.My HUD on my 2ooo FRC stays programed the way I have it.Fuel,Tach,MPH. Ofcourse this is the only one I've driven.
Old Apr 20, 2005 | 11:46 PM
scoaman's Avatar
scoaman
Mine stays to what ever I last had showing in both my 1999 vert and 04 vert.
Old Apr 20, 2005 | 11:52 PM
Tom73's Avatar
Tom73
Do they default to the Memory Package settings?
Old Apr 20, 2005 | 11:53 PM
DAS ZED's Avatar
DAS ZED
Sorry, never had that problem.
Old Apr 21, 2005 | 12:07 AM
GrayC5's Avatar
GrayC5
What am I missing?
According to my Owner's Manual, the selection you last chose should remain in the HUD until it is changed. That's the way mine works.
Old Apr 21, 2005 | 12:13 AM
Z-07 freak's Avatar
Z-07 freak
I agree that's how it should work. But I have seen quite a few pass through my store that have this gremlin. I can not frekin figure out how to fix it.
Old Apr 21, 2005 | 07:21 AM
Mine stays on the settting I select too. Wish I could be of help, but electrical problems are way out of my league. Hope you can find out the reason your's is doing this.
Old Apr 21, 2005 | 07:23 AM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Old Apr 21, 2005 | 09:59 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
It's your battery. I had the same problem and then months later I realized that my original equipment battery was about to go. I changed to an Optima Red top and the problem cleared up.
Best of luck,
rr
Old Apr 21, 2005 | 09:23 PM
Z-07 freak's Avatar
Z-07 freak
That's it!
I read your reply this morning, then at work I tested out your theroy.
I started it (`01 vert) switched it to coolant, turned it off, restarted it, and it showed oil. I tried that a few times, with the same results. Then I connected a charger set at 12v medium, and tried it again a few more times. It stayed at coolant every time. As soon as I removed the charger and started it... oil was back.
So I guess when your HUDs secondary gauge resets to oil from fuel level or coolant, it's a sign your battery has one foot in the grave.
To HUD question
