Hello
We have a 2000 with 5200 yea 5200 miles leakind oil from drivers side
of rear end chunk seems to be where half axle inserts any info would
be of great help. Leaked about a teaspoon full in the last week or so
Thanks in advance.......Had the vette about two months
Yep, very common problem. There have been several service bulletins issued on the problem. Part of the problem, as I understand it, was due to the differential cover seal which was redesigned. One service bulletin, issued around Oct 2003 I believe, spelled out replacing the real axle seal and differential cover seal with newly designed seals. You may be able to find some past threads that discuss this futher by using the Forum search feature. Good luck with the fix.
Don't know how new the procedure is, but had my 2004 in to get the same leak fixed about 4-5 months after purchase (brand new).
my 04 also leaks and has 2100 miles on it. not dripping but i can see evidence of it from passenger side only.
also i have seen here that many have had it fixed multiple times...
Same with my 04.......dealer fix it and still leaks.
I have a late model leaky rear 04, when was it redisigned?
I have seen many posts of having it to the dealer 2 or more times
for the same problem. After a 8 year run, the general can't get it right.
This shouldn't be!
04 with the same mileage and same problem, dread taking it back to the dealer
