I am sooooo stupid!
Pictures are in my blog entry...
I am sooooo stupid!
That said... no major damage to the car. Nothing some touch-up paint can't fix. But the garage door was jammed and I couldn't get to a meeting.
OUCH.
j/kThat's not even close! It had to be WAY low to get your trunk lid!
Sorry it happened. And I know how you feel, I've removed a side view mirror backing out of the garage before (not on the vette and I was a teenager then though).
I was expecting the door to be somewhat opened and you misjudged but that wasn't even close.
But hey, don't feel bad.... some days I feel more stupid than smart.
Glad you didn't do more damage than you did.
Mark
1) Yes, I do realize I'm stupid. In the form of a Stup-a-holic, I would like to introduce myself:
"Hi, my name is Flip, and I'm stupid..."
2) That said, the garage door fooled me because of a complex optical illusion brought on the stupidity I acknowledge in step 1.
Thinking back on it, I was looking out the *side* mirror and saw the door up, when I should have checked my *rear view mirror*. 3) I absolutely, positively, 100% thank God for the damage to the car being so minimal (but hey, I'm sure if I'd done a proper burnout and launched well, I could have burst right through the door properly!)
It was such a low-speed collision I was surprised the door even took as much damage as it did! So yep, while it did suck, the door is operational (and will be repaired in 2-3 weeks) and the car needs nothing more than some delicately applied touch-up paint.
Yeah, it doesn't take much for those doors to get torn up... and they're not cheap to repair. Maybe you ought to look into plastic beads like the hippies used to use as doors?
Nonetheless, you're okay and the car needs some minor touchup. If that's the worst thing any of us do, life isn't that bad.
Mark
Get her fixed and forget about it, but don't forget to check your garage door being all the way open.
Had to slide that in.Later
Darion
It could have been worse, good luck with the repair
It can be fixed
for an hour
(sorry, couldn't resist)
