Plenum Cover install question
Old Apr 23, 2005 | 04:47 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Default Plenum Cover install question
TKO Performance package just came in. Having a little difficulty installing the plenum cover. It's a 1 piece "aluminized" plenum cover. Just cant figure out how this fits under the bar that runs across the middle. Any suggestions!?!?
Old Apr 23, 2005 | 04:51 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
you have to pull up the injector's & fuel rails
Old Apr 23, 2005 | 04:56 PM
BAMF AE's Avatar
BAMF AE
I have already took out the frc's. Not sure how to pull out the injectors. I've unscrewed the four bolts, but still have troubles lifting the entire piece up to slide plenum under. Maybe some pics may be needed.
Old Apr 23, 2005 | 05:38 PM
EatRice's Avatar
EatRice
FIRST make sure that the area around the fuel injectors is clean....no dirt or debris. That is very important. The fuel rail is only held on by those bolts you removed. The injectors are pressed fitted. So it takes a little bit of pulling to get them out but you can get the fuel rail up with all 8 injectors usually. I would not remove the fuel rail...just lift it up high enough to slide the cover on.
Old Apr 23, 2005 | 06:21 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
It took me about 30 minutes to install.
Old Apr 23, 2005 | 07:49 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I tied a piece of small dia. rope around the crossover rail and pull up (kinda hard) until the injectors pop out. Careful not to lose the o rings.............
To Plenum Cover install question
