DRL Removal
Old Apr 23, 2005 | 05:44 PM
CN RED's Avatar
CN RED
Default DRL Removal
I'm getting that fast flash when I turn on my right turn signal. I realize that it's a blown bulb. I already checked the fuse and that's not the problem.
Now I'm just wondering how to get to the bulb. Do I go from underneath or from uptop. Meaning, do I just removal the bezal around the headlight housing to get to it or do I just go from underneath and remove the plastic housing that covers the lights electrical from underneath?
I can touch both bulbs from up top but I can't seem to remove the one in front (DRL). The last question is..... When I push down on the release tab do I just pull it out or do I screw it out?
Thanks in advance. My right DRL has been out for 2 weeks and it's driving me crazy. I want to fix today.....NOW
CN RED
Old Apr 23, 2005 | 05:55 PM
CN RED's Avatar
CN RED
Disregard I got it out........
CN RED
Old Apr 24, 2005 | 07:34 AM
newyiddy20's Avatar
newyiddy20
that happened to me about 3 times in 2 mos.........i think there something going on that breaks bulb,stay tuned. and it onlys happens on the right side,ummmm
Old Apr 24, 2005 | 08:17 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Sometimes the bulb will melt a hole in the top of the housing. You may want to check to see if that has happened to yours. If so then you can try to patch it with a piece of plastic and some sealant so this annoyance goes away.
To DRL Removal
