need help with rocking seat issue
Old Apr 23, 2005 | 06:13 PM
pdd000's Avatar
pdd000
Default need help with rocking seat issue
http://media.fastclick.net/w/get.med...1&tp=5&d=s&c=1
i tried this site but my blocks have no play in them. the gromets are in perfect shape. any other ways to fix this the rocking seat?
thanks pat
Old Apr 23, 2005 | 07:22 PM
iteachflyin's Avatar
iteachflyin
Change the seat tracks. That's what the dealer did for mine.
Old Apr 23, 2005 | 07:25 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
How much for the seat tracks?
Old Apr 23, 2005 | 07:30 PM
pdd000's Avatar
pdd000
did it work???
Old Apr 23, 2005 | 07:39 PM
iteachflyin
Originally Posted by pdd000
did it work???
Worked perfectly, no more rocking at all. A friend of mine who owns the Corvette Shop in Montgomery NY told me that it was a common problem and that was what he would have done. In fact, based on what he told me, I told the dealership and they did it, and it worked.
Old Apr 23, 2005 | 07:54 PM
pdd000's Avatar
pdd000
do you know what part numbers they are?
Old Apr 23, 2005 | 10:34 PM
pdd000's Avatar
pdd000
Ttt
Old Apr 24, 2005 | 07:12 AM
DsC5's Avatar
DsC5
my stock seats didn't rock, now with the caravaggio seats, it rocks a little bit. everything is tight as far as I can tell.
Old Apr 24, 2005 | 07:25 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
I got mine covered under warranty. There is a TSB out addressing this problem. I don't have the TSB number handy, but I can find it if you need. I believe they replaced the seat track, but not positive. I know it's nice to drive without the rocking chair effect.
Old Apr 24, 2005 | 06:39 PM
pdd000's Avatar
pdd000
ya could you find it for me. thanks pat
Old Apr 25, 2005 | 07:08 PM
pdd000's Avatar
pdd000
Ttt
Old Apr 25, 2005 | 08:06 PM
kenrobb's Avatar
kenrobb
New GM set track is about $450 from GMPartsDirect.com. List is $750 or so. That is the only solution to rocking seat if the repair (install washers) doesn't work. You almost have to take the track apart to tell if the block has play in it I would think. You might try getting a take-out from a salvage newer model year.
Old Apr 26, 2005 | 07:43 AM
DDsC5's Avatar
DDsC5
Default LESS COSTLY ALTERNATE to REPLACING SEAT TRACKS??
In my 99 the rails appear tight but the grommets holding the seat to the rail appear to be loose...Does anyone know if drilling out the grommets/rivets(whatever they are called) and replacing them with black anodized bolts and locking nuts on the underside is an option? Before I start drilling, I would like to know that someone else has been successful
To need help with rocking seat issue
