Previous Owner
Old Apr 23, 2005 | 09:30 PM
sealoution's Avatar
sealoution
4th Gear
Default Previous Owner
Can any run my VIN (1G1YY22G025116105) and tell me who was the previous owner and build information?
Old Apr 23, 2005 | 10:27 PM
ArmyVette's Avatar
ArmyVette
Carfax will not show previous owner information. It will tell you which state(s) the vehicle has been register in either by an owner or by a dealer but that's about it.
What did you buy?
Old Apr 23, 2005 | 11:25 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
If you have the original owners manual for the car look inside the front page and you should find the name and possibly the address of the original owner.
Once you find the name you can go to anywho.com and probably find an address and telephone number. I tracked down the original owner of my '02 this way and boy was he surprised and I might say pleased to hear from the new owner of his "baby".
The original owner may be able to answer questions about the car's service history. etc.
Old Apr 24, 2005 | 01:26 AM
A dealer can give you a printout of the service history and build information based on your VIN. As for the previous owner, if it was someone in your state, your DMV may be able to help.
Old Apr 24, 2005 | 09:22 AM
C54DAZ's Avatar
C54DAZ
Default here you go!
GM Vehicle Inquiry System
Vehicle Build
VIN 1G1YY22G025116105
VEHICLE BUILD
Merchandising Model : 1YY07 -2002 CORVETTE COUPE
Gross Vehicle Weight Rating : 1676 kg (3696 lb) Order Number : DSXZQF
Build Date : 12/10/2001 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS
CC3 - TRANSPARENT LIFT-OFF ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE3 - SPORT SUSPENSION G90 - REAR AXLE-3.15 RATIO
G92 - 3.15 PERFORMANCE AXLE RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NC1 - CALIFORNIA EMISSIONS LEV
NG1 - 50-STATE LOW EMISSION VEHICLE NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
R7C - EXPEDITE PROCESSING OF ORDERS R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - COMPACT 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE 1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
70U - TORCH RED
© 1998-2004 General Motors Corporation. All Rights Reserved.
Old Apr 24, 2005 | 09:23 AM
C54DAZ's Avatar
C54DAZ
And more....
Claim History
VIN : 1G1YY22G025116105
CLAIM HISTORY
Repair Order Date : 11/15/2004 Repair Order Number : 301379 Odometer Reading : 35601 miles
Serviced By : NORWOOD CHEVROLET
1338 POST RD
WARWICK, RI 02888-3293
(401) 781-4300 Selling Source : 13 - CHEVROLET
Site Code : 32364
Business Associate Code : 115060
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
12/21/2004 545 01 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC N/A N
Repair Order Date : 10/27/2004 Repair Order Number : 299872 Odometer Reading : 35578 miles
1338 POST RD
Site Code : 32364
12/21/2004 545 01 # C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 10344131 - REGULATOR N
Repair Order Date : 03/11/2004 Repair Order Number : 279105 Odometer Reading : 27829 miles
1338 POST RD
Site Code : 32364
03/16/2004 465 01 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 10407815 - PLATE ASM N
03/16/2004 465 02 # N6606 - WIRING AND/OR CONNECTOR - FUEL SYSTEM - REPAIR OR REPLACE N/A N
Repair Order Date : 03/02/2004 Repair Order Number : 278231 Odometer Reading : 26455 miles
1338 POST RD
Site Code : 32364
03/05/2004 462 01 # R0763 - RECEIVER, RADIO - REINSTALL RADIO N/A N
03/05/2004 462 02 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE N/A N
Repair Order Date : 02/18/2004 Repair Order Number : 277073 Odometer Reading : 25403 miles
Serviced By : MODEL ELECTRONICS
318 ROOSEVELT
SPRING VALLEY, NY 10977
Selling Source : 45 - A/C DELCO
Site Code : 19050
Business Associate Code : 192106
03/12/2004 464 01 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 09391636 Y
Repair Order Date : 02/17/2004 Repair Order Number : 277073 Odometer Reading : 25403 miles
1338 POST RD
Site Code : 32364
02/24/2004 459 01 # L1224 - SENDER/PUMP ASSEMBLY, FUEL (TANK UNIT) - RIGHT TANK - REPL 89047748 - MODULE KI N
02/24/2004 459 02 # R0762 - RECEIVER, RADIO - REMOVE RADIO N/A N
Repair Order Date : 10/26/2002 Repair Order Number : 084653 Odometer Reading : 10918 miles
Serviced By : HURD BUICK CHEVROLET, INC.
1705 HARTFORD AVE
JOHNSTON, RI 02919-3203
(401) 751-6000 Selling Source : 13 - CHEVROLET
Site Code : 32304
Business Associate Code : 117960
12/17/2002 335 01 # Z8050 - MAINTENANCE (LUBE OIL FILTER) N/A Y
Repair Order Date : 12/10/2001 Repair Order Number : A16105 Odometer Reading : 0 miles
Serviced By : HILLCREST CHEVROLET
207 HIGHLAND AVE
SALEM, MA 01970-1829
(978) 744-9721 Selling Source : 13 - CHEVROLET
Site Code : 32343
Business Associate Code : 114960
12/14/2001 230 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Old Apr 24, 2005 | 09:26 AM
C54DAZ's Avatar
C54DAZ
and more.....
Summary
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE Warranty Start Date : 01/14/2002
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : HILLCREST CHEVROLET
207 HIGHLAND AVE
SALEM , MA 01970-1829
(978) 744-9721
Site Code : 32343
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 01/14/2002 10 miles 01/14/2005 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 01/14/2002 10 miles 01/14/2008 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/14/2002 10 miles 01/14/2010 80010 miles
84/70000 CALIFORNIA SELECT COMPONENT 01/14/2002 10 miles 01/14/2009 70010 miles
36/50000 CALIFORNIA EMISSIONS 01/14/2002 10 miles 01/14/2005 50010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/15/2004 301379 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 35601 miles
10/27/2004 299872 # C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 35578 miles
03/11/2004 279105 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 27829 miles
03/11/2004 279105 # N6606 - WIRING AND/OR CONNECTOR - FUEL SYSTEM - REPAIR OR REPLACE 27829 miles
03/02/2004 278231 # R0763 - RECEIVER, RADIO - REINSTALL RADIO 26455 miles
03/02/2004 278231 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 26455 miles
02/18/2004 277073 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 25403 miles
02/17/2004 277073 # L1224 - SENDER/PUMP ASSEMBLY, FUEL (TANK UNIT) - RIGHT TANK - REPL 25403 miles
02/17/2004 277073 # R0762 - RECEIVER, RADIO - REMOVE RADIO 25403 miles
10/26/2002 084653 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 10918 miles
12/10/2001 A16105 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Apr 24, 2005 | 09:29 AM
C54DAZ's Avatar
C54DAZ
Sorry cant tell who the prev owner was.
To Previous Owner
