changing rearends
Old Apr 24, 2005 | 10:13 AM
steves red vette's Avatar
steves red vette
Default changing rearends
i have 273 gears in my vette, can i just change the gears or do i have to change the rearend . i am looking to get 342,s.
Old Apr 24, 2005 | 10:18 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
if you have a good case I have the internals of my 3:42's...top of the case cracked where the bolt goes thru..everything else is
Old Apr 24, 2005 | 10:23 AM
Mike Mercury's Avatar
Mike Mercury
when you ask... can "I" change gears.... well no - not in a 2.73 case.
It can be done though , but it takes a custom made part that is not available to the DIY'er. Right now, only DTE can swap-in bigger gears into a 2 series case.
Even with a 3 series case, internal gear swapping is best left to the professional. The C5 Getrag carrier (diff) is unique.
http://mikemercury.home.att.net/342.htm
Old Apr 24, 2005 | 11:40 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I agree.
Check out DTE. They will sell you a lower gear professionally installed in a carrier. A complete unit. And they will take your 2.73's for a core, they are the only ones who take 2.73 differential cores. They have a special process that Tim mentioned earlier that allows them to rebuild the 2 series carriers with 3 and 4 series gears.
Don't forget to reprogram you PCM after the gear install, or else you'll be bouncing off the limiter at WOT.
My first C5 had 2.73's, I installed 3.42's. I liked the 3.42's, they are without a doubt the most popular gear choice for the A4.
My current C5 has 3.15's, and I just ordered 3.73's. Fun, fun, fun. I debated 3.90's but I thought they were a little too tall.
On a side note. 3.73's are only available from Getrag right now(the OE supplier to GM). Motive Gear, who makes the 3.73 ring and pinion for rebuilding differentials, has had some troubles with the 3.73's. So DTE has not built one in a while.
Here is a good gear calculator http://www.kabamus.com/garage/gears.html
Have Fun,
AZC5
PS. Sorry for the long winded post, I had too much coffee this morning!
To changing rearends
