2000 Window Motor
Old Apr 24, 2005 | 09:21 PM
mwbmd11's Avatar
mwbmd11
Default 2000 Window Motor
The passenger window will not roll down on my 2000. I'm assuming its the motor. Has anyone changed one out? Just wondering how much of a project it will be. Also is there a good aftermarket supplier for the motor?
Old Apr 24, 2005 | 10:37 PM
double-oh-coupe's Avatar
double-oh-coupe
I've had the same (intermittent) problem on my 2000 ... a tip from the forum I have used is to pull off the door panel, and while holding down the button to rool down the window, take the head of a screwdriver and tap the door panel right where the motor is mounted on the inside (might have to give it a little more than a 'tap'. Everytime I've done this the motor kicks back to life and works for a while. Kinda a PITA, but better than buying/installing a new one (at least for now).
Hope it helps ... Chris ...
Old Apr 24, 2005 | 10:48 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Friend of mine has had the pass side motor replaced twice now in her 50th an. model..
(btw, window is hardly ever raised and lowered)
To 2000 Window Motor
