Lug nut torque
Apr 25, 2005 | 11:12 AM
CI 4-5-6-7 Veteran
Lug nut torque
I just looked in the manual out of morbid curiosity and it calls for 100ft-lbs? That's all?
Apr 25, 2005 | 11:13 AM
St. Jude Donor '11-'12-'13, '15
Apr 25, 2005 | 11:18 AM
Cruise-In VI Veteran
St. Jude Donor '05
Dont forget to torque them in 20ft lbs increments in a star pattern up to 100lbs.
http://www.tirerack.com/wheels/tech/torque.jsp
Apr 25, 2005 | 11:29 AM
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Try 750 lbs on the Enzo, since they have one BIG lug in the middle.
Ours are collectively 500 lbs,, which isn't too shabby
Apr 25, 2005 | 12:11 PM
750 lbs, that's it??? I could do that with my leatherman!
Apr 25, 2005 | 12:22 PM
CI 4-5-6-7 Veteran
That's a long damn cheater-pipe.
Apr 25, 2005 | 12:26 PM
Thats all? I thought 100 ft lbs was alot when I first got the car. All my previous cars were 70 or so, granted they werent as powerful...
Apr 25, 2005 | 01:05 PM
That's the correct final torque number. I do mine progressively, from 60, to 80 then 100.
Apr 25, 2005 | 01:19 PM
I chose the 50-75-100 route.
Apr 25, 2005 | 01:25 PM
I cheat a little: tighten them down with a regular socket then go 80 - 100. Not really much difference and I've had the wheels off of my car enough to know about where 50-60ft-lbs, and It saves some time.
Apr 25, 2005 | 01:46 PM
Quote:
I went 10-20-30-40-50-60-70-80-90-100.
DAYUM YALL!
Apr 25, 2005 | 04:36 PM
What did you think....they were lying to you???? 100 ft/lbs has been a standard spec for most vehicles for years. Don't have a torque wrench,use a wobble stick with your impact.
Now the spec on oil capacity is wrong, it should read fill to top, then stop just before it overflows.
Apr 25, 2005 | 05:20 PM
CI 4-5-6-7 Veteran
I always used "160ft-lbs" by standing my 160lbs on the end of a 1ft wrench.
Apr 27, 2005 | 09:45 AM
I dont know which manual you are looking at but I knew mine were on tighter than this, so I went and checked the service manuals for my 2001 and it states 190Nm (140ftlb)
