Zip Tie Weatherstrip question
Old Apr 25, 2005 | 02:38 PM
matt24's Avatar
matt24
Default Zip Tie Weatherstrip question
Was just at home depot and couldnt find anything buy very soft weatherstriping, arent i supposed to use more of a rubber strip? They had it but it was for a window and was curved on the top but i guess that wouldnt matter? Can I use that? Thanks!
Old Apr 25, 2005 | 02:41 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
You need to head to Lowes and look for the "Tear Drop" shapped black polyeurothayne weatherstrip with adhesive backing. I believe it's about 15.00 or so and roughly 72 inches in length. You'll just have to measure it and cut it down to size before applying. Very simple procedure. Takes all of approx two minutes for the entire process. If you make a mistake, dont worry. You've got 72 inches to work with.
Good luck
Old Apr 25, 2005 | 02:48 PM
matt24's Avatar
matt24
Got ya thanks, will try lowes tonight!
Old Apr 25, 2005 | 04:15 PM
NCSU SEE 5's Avatar
NCSU SEE 5
From: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Can someone post pics using the Lowes weatherstrip?
Thanks!!
Old Apr 25, 2005 | 09:07 PM
matt24's Avatar
matt24
Ok im lost. I went to home depot and lowes and cant find it. Who makes it and where in the store is it, i went to where all the weather striping is and nothing close and prices are way off. Is it supposed to be for a door or a window? I asked for help and they all had no idea.
Old Apr 25, 2005 | 10:40 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
there is a decent picture here (and reasonable price too)
Old Apr 25, 2005 | 11:18 PM
matt24's Avatar
matt24
Nice but i need something tomorrow bc if it rains im screwed lol.
Old Apr 25, 2005 | 11:23 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
I found some that was very close to this version at an auto supply store - it was about $20 for 10'. It was 9/16" wide by 3/4" thick.
Old Apr 28, 2005 | 08:32 PM
speedydog5's Avatar
speedydog5
do you need to do the weather strip with the zip tie mod ,what does the weather stripping do to benefit the air cleaner ,I would think any air getting through the gap in the hood would mean more cold air into the filter I just put a zip tie on with the K&N?
To Zip Tie Weatherstrip question
