HELP...looking for part
Old Apr 25, 2005 | 09:44 PM
GMvert's Avatar
GMvert
Default HELP...looking for part
I was changing out my stock shift boot for a short throw boot and I broke the plastic ring thingy that holds the shift boot in the console. Is this part available by itself?
Old Apr 25, 2005 | 11:40 PM
GrayC5's Avatar
GrayC5
Neighbor,
I assume you're referring to the manual shifter. For model years 1997 through 2001, the retainer was only available as part of the boot/retainer assembly. I'm not certain about later model years. Check with Gene's Kar Shop, a Forum vendor, and he may be able to help you with a used one. Good luck.
Old Apr 25, 2005 | 11:46 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
many have tried to find it, but it is part of the boot assembly...
Old Apr 26, 2005 | 12:12 AM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Mine has been broken for over a year...BUT.......nobody knows but me I put my V/E boot on and it works and looks just fine
Old Apr 26, 2005 | 04:46 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Did you break it OR was it broken...everyone seems to have a broken plastic retainer..can't buy it separately...mine was broken and I removed the stock shft boot (PITA between the glue and staples ) and I installed the redline stuff..I used Vinyl adhesive I got from fabric store to hold the new piece in place..also worked great for the e-brake boot to wrap the leather around the stock wire ring....I have pics if you are interested
To HELP...looking for part
