Gas Tank Location????
Apr 26, 2005 | 05:56 PM
I want to mount my amplifier behind the driver seat.. but im worried about drilling holes there...
Apr 26, 2005 | 05:59 PM
From: Vette Doctors Performance RX450 - 466RWHP !!!
Drill slowly and have gum handy incase you spring a leak!!!!!!
Apr 26, 2005 | 06:11 PM
Quote:
I was hoping i had some room... How close is the tank does anyone know?
Apr 26, 2005 | 06:26 PM
St. Jude Donor '05-'06-'07-'10
Don't think there is much. If I wasn't sure I wouldn't play there.
Use rubber drill bits.
Apr 26, 2005 | 06:31 PM
Consider gluing instead of drilling. A mistake could be costly.
Apr 26, 2005 | 06:37 PM
Quote:
Those panels are glued to the car anyway.
Apr 26, 2005 | 06:46 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Very little room in between there as I recall from previous threads about this topic.
Apr 26, 2005 | 08:30 PM
Don't do it!!! I bought a used C5 with an aftermaket stereo with some equipment mounted in that spot. When the PO removed the equipment to return to stock he caused a leak in the gas tank. Apparantly he had drilled right into the tank and the screws kept the tank sealed until he removed them. Cost me $1000 to fix. DON'T DRILL IN THAT SPOT!!!!
