Car locking and unlocking by itself.What could be wrong?
Old Apr 27, 2005 | 07:31 PM
jules9's Avatar
jules9
Default Car locking and unlocking by itself.What could be wrong?
Every time i use the fob or manually lock the doors when iget out it locks itself or if i lock it ,it unlocks without touching anything.What could be wrong? Thanks.
Old Apr 27, 2005 | 07:36 PM
RandW's Avatar
RandW
Passive set on key fob? Don't know what style fob you have but if it has a passive switch set it to off.
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Depending upon what year Corvette you have, pre 2000 models have a "passive" lock and unlock feature controlled by a slide switch at the bottom of the remote keypad. If this is set to on, the car will unlock when the fob gets within range and or lock when fobs leaves the range.
Paul
Old Apr 27, 2005 | 08:11 PM
jules9's Avatar
jules9
that did the trick.THANKS.
Old Apr 28, 2005 | 09:07 AM
vetdude's Avatar
vetdude
Paul
Year 2000 cars don't have the passive fobs?????? I just a used '00 Vert and it came with passive FOBS...that don't work by the way. Maybe this is why?
Old Apr 28, 2005 | 01:14 PM
No, they did away with the passive feature after the '99 year. My '00 does not have it. Could be they have the wrong fobs.
Old Apr 28, 2005 | 01:43 PM
vetdude's Avatar
vetdude
You are correct JD. I just cross checked the part # of the fob that came with the car against the part # for a '00 - wrong fob. Looks like the guy owes me two fobs.
Old Apr 28, 2005 | 01:50 PM
Tombone's Avatar
Tombone
I knew nothing about this option at first.
I parked my car at the side of the house and had the keys in my pocket while I was in side.
I couldn’t understand why the car kept beeping the horn.
The answer was every time I came close to the car while still inside the house the fob would unlock the door, and relock with a toot because the door was not opened.
Old Apr 28, 2005 | 06:38 PM
stevzc5's Avatar
stevzc5
Its kinda cool, but the passive setting drove me nuts when the car unlocked or locked every time I walked by, so I set it to off.
To Car locking and unlocking by itself.What could be wrong?
