[Z06] Cat Problem (02)
Old Apr 27, 2005 | 09:00 PM
DOG-BOY's Avatar
DOG-BOY
Default Cat Problem (02)
I have Z06 with long tube headers random cats B&B exhaust. The thing keep throughing codes (if it keeps it up I'm going to have change the check engine bulb). Has anyone else having this problem, if so how did you fix it. I DO have LS1 EDIT.
Old Apr 27, 2005 | 09:33 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
It all depends on what the issue is. Do you have all 4 O2 sensors installed? What are the codes your getting? My LG's had only 2 bungs and the installer did not edit out the other two so I threw a code once a day. I bought a set of O2 sims and that corrected the problem. If all four are installed then that would be a different issue. Certain LT's don't produce the right amout of heat for the rear O2's and that can cause problems.
Old Apr 27, 2005 | 10:15 PM
DOG-BOY's Avatar
DOG-BOY
Yes all 4 are installed. po430 and po420 TWC System Efficiency Bank1 and Bank 2
Old Apr 27, 2005 | 11:26 PM
Evolution's Avatar
Evolution
Those are your rear 02's throwing codes. You need to turn them off with Edit, or get 02 sims. I know you said you had edit, but are they turned off?
Old Apr 30, 2005 | 11:16 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Yes, even if you have cats.. the rears can still set a code with headers.
To Cat Problem (02)
