Problems with the key fob yet again...
Old Apr 29, 2005 | 02:28 AM
SPD KILZ's Avatar
SPD KILZ
Default Problems with the key fob yet again...
Well iv had it reprogrammed by my local chevy dealer 3 times in the last 2 months and again tonight it lost its memory... What is wrong with the dang thing? Anyone have this repeating problem?
Old Apr 29, 2005 | 05:49 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It sounds to me like you need a replacement.
Old Apr 29, 2005 | 06:01 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
VR
Old Apr 29, 2005 | 06:08 AM
C5naples's Avatar
C5naples
Happened to me, bought a new one . No problems since. Apparently they don't last forever.
Old Apr 29, 2005 | 07:07 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Same thing happened to me. Reprogrammed it several times and it kept loosing its memory. Changed the battery, relearned it and it kept loosing its memory. Cleaned the ground on the front wheel well (can't remember if it was driver's or passenger's) and it has been working fine since (several months).
I followed instructions w/ images written up by member Bill Curlee to clean the grounding point. The write-up has been moved or deleted. Here's the old link: http://forums.corvetteforum.com/show...hlight=key+fob
Maybe you can PM Troy (forum owner) to point you to this thread or contact Bill Curlee (forum member) to give you further instructions.
Good luck!
Old Apr 29, 2005 | 07:13 AM
I'd try a new fob first and see if that cures your problem. If it continues to act up, it could be the receiver in the car. I had this happen on my '99 and the dealer had to replace the receiver - worked fine after that.
Old Apr 29, 2005 | 08:16 AM
TOPGUN9's Avatar
TOPGUN9
I had mine replaced under the extended warranty.
Old Apr 29, 2005 | 08:19 AM
C5 4 ME's Avatar
C5 4 ME
Old Apr 29, 2005 | 08:21 AM
Postergeist's Avatar
Postergeist
I've given up on mine. Sounds like it's unlocking the door, but it's not - have to use the key. This is an '02 - didn't have problems with the '01 or even the PKE on the '96.
Old Apr 29, 2005 | 11:57 AM
YBNORML's Avatar
YBNORML
Me too!!!
Old Apr 29, 2005 | 01:51 PM
vetdude's Avatar
vetdude
same here...and it wasn't cheap!
Old Apr 30, 2005 | 12:36 PM
DAWS C5's Avatar
DAWS C5
A possibility is the battery loses contact when the fob is bumped. Pretty easy to do, even when in your pocket. Try gently prying up the battery contacts so they press harder on the battery. Worked for me - no problem in last 4 years.
Old Apr 30, 2005 | 04:06 PM
boss302's Avatar
boss302
Try monitoring your tire pressures (car has to be moving). It is the same receiver that gets the signal from your key fob transmitter. If the tire pressures read out and the key fob doesn't work, then the problem is with the key fob.
Old Apr 30, 2005 | 04:13 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I went through something like this too...after 3 different batteries, it then worked and is still working fine (2 years now or so)
To Problems with the key fob yet again...
