FRC vs ZO6??????? HELP!!!!!!!!!!
Old Apr 29, 2005 | 03:36 PM
bigcityvette's Avatar
bigcityvette
Default FRC vs ZO6??????? HELP!!!!!!!!!!
Hello,
what is the difference between the FRC and the ZO6? Im assuming the ZO6 has more power? When did the ZO6 come out? How much power does the FRC have?
Any known problems with the FRC?
They seem to be going in the $20K range so im looking at maybe picking one up.
Thanks!
Old Apr 29, 2005 | 03:40 PM
JoshVette's Avatar
JoshVette
FRC's came out first in 1999 and the Z06 came out first in 2001 with 385HP at crank and in 2002 Z06 had 405HP at crank.
I believe the FRC in 99 was just a normal LS1 with 350HP...
I'd get a Z, no question over an older FRC.
Old Apr 29, 2005 | 03:50 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
It depneds what your out to do. I own my car with the mods for about 27 to 28k which is less than a nice 2002 Z06 would cost and I am faster than a stock 2002+ Z06.
Now you could make a Z06 faster than me obviously, but I would then own my car for much less than you paid. Oh and I bought my car with 23k miles on it.
P.S. Actually when I get my gears and diff brace installed I own it for 30k but even still.........
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
FRC 99-2000 345 hp
ZO6 01s 385 hp
ZO6 02-05 405 hp
Old Apr 29, 2005 | 03:58 PM
bigcityvette
so the frc just was a 2 door w/o the targa and the standard c5 motor.
humm............
And then the zo6 in 2001
thanks. any known problems etc with these cars?
Old Apr 29, 2005 | 04:08 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by JeepTJ
ZO6 02-05 405 hp
There was no Z06 in 05
Old Apr 29, 2005 | 04:09 PM
JoshVette's Avatar
JoshVette
humm............
I've heard to stay away from the 01 Z's due to the improvements they made on 02's......
I dont' know if 01's Z's are bad, just less power.
Old Apr 29, 2005 | 04:13 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
humm............
One major problem is trying your hardest to keep it stock!
Old Apr 29, 2005 | 04:19 PM
JoshVette's Avatar
JoshVette
I believe that's a GM Manufacturer's defect.......did you get the recall for it yet??
Old Apr 29, 2005 | 04:28 PM
IMXCITD's Avatar
IMXCITD
If you can afford it and it's not a huge difference...then get the Z! Either way...get one of them and you will be a happy camper!
Old Apr 29, 2005 | 04:35 PM
QuikZilver's Avatar
QuikZilver
There is a lot more to a Z than just some engine mods. Check out www.z06forum.com. They have a nice breakdown there as to what the differences were. As for issues with 01 Z's, there are 2 that are possible.
1. Oil Consumption: Solution is re-ringing the lower 2 rings on the motor.
2. Clutch Slave Cylinder: After a couple quick high rpm shifts the pedal goes away, solution is replacing with newer slave.
Both of these have technical service bulletins on them. I bought my 01 with 14,000 miles and have almost 30,000 now (1 year in July). I got it with an extended GM warranty, which I would recommend if you can get it(sold by dealers). I have the second issue, oil consumption is fine on mine. Not all had these problems. Good luck!!
Old Apr 29, 2005 | 05:14 PM
Mr. C's 5's Avatar
Mr. C's 5
[QUOTE=bigcityvette]so the frc just was a 2 door w/o the targa and the standard c5 motor.QUOTE]
No..... it was a HARDTOP! A completely new body style in 99. Returned in 00 with some improvements and then became the basis for the Z06. There's a ton of information and pictures out there about this if you look for it. - C.
Old Apr 29, 2005 | 05:18 PM
Horsepower for the Z06 was 385 in '01 and from '02-'04 it was 405. FRC was from '99-'00 and the HP was 345.
Z06 came out in '01. Probably the best known problem was with the '01's and that was for oil consumption.
Old Apr 29, 2005 | 07:14 PM
bigcityvette
is the only difference between the FRC motor and the ZO6 motor the cylinder heads, intake, cam and im assuming the computer? Is it he same lower block (crank, rods, etc) as the ZO6?
Old Apr 29, 2005 | 08:21 PM
tdahl's Avatar
tdahl
major from an LS1 as an FRC to a LS6....... different motor.
To FRC vs ZO6??????? HELP!!!!!!!!!!
