Borla Stinger Install Tips?
Old Apr 30, 2005 | 01:16 PM
viper8u2's Avatar
viper8u2
Default Borla Stinger Install Tips?
Hello Guys/Gals!
After hunting for a used Borla system, I have finally given up and ordered a new one yesterday. It should be here next week.
After looking at the instructions, It doesnt look to hard to put it in. The hard part looks like getting the stock one out.
Can I easily get the stock one out by using a set of ramps and jacking up the rear? Do I need to cut it? I was thinking of getting the plastic rhino ramps people have talked about at sears.
How long has it taken some of you to do this?
Any tips for a newbie? Should I just bring it to an exhaust shop? and if so, how much is a reasonable price for them to do the swap?
I have only had the car for a couple of weeks and havent even made my first car payment and I have been bitten by the mod bug already
Thanks for any tips,
Mike
Old Apr 30, 2005 | 01:19 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
I had mine installed several years ago at a muffler shop. The guy really took his time and, if I remember correctly, only charged me about $40.00. Well worth the price, but you gotta watch where you take it.
If you do it yourself, you'll need to jack the rear up (I think yu'll need about 33 inches or so, but I may be wrong) and remove one of the sway bar bolts. If not, it makes it hard to remove the original. Hope that helps.
Old Apr 30, 2005 | 01:39 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Same here, $40.00 at Midas to put on my Magnaflow's a couple years ago.
Old Apr 30, 2005 | 01:40 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
If you cut it out, you won't need more than the rino ramps. If you want it out whole, you have to get the back of the car way up in the air...
I cut mine out and it was easy as pie...
Took about 2 1/2 hours, but I put an X-pipe in at the same time and drank some while I was at it. You could do a cat back in an hour if you busted it out...
Peace
Willfulone
__________________
..................Click for
viper8u2's Avatar
viper8u2
Thanks 98blackmagic,
If I can find a shop to do it for that price, I wont think twice about it. Not worth the hassle for me
Keep the tips coming
Mike
Old Apr 30, 2005 | 02:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Here you go - step by step with pictures.
EG
http://forums.corvetteforum.com/show...7&forum_id=103
Old Apr 30, 2005 | 02:14 PM
viper8u2's Avatar
viper8u2
Thanks EG,
Nice job on the writeup, that helps alot. Exactly what I am putting in.
Mike
Old Apr 30, 2005 | 02:25 PM
DreamVette97's Avatar
DreamVette97
I say do it the right way. Dont cut the stock ones. I used a lift so it only took a max of 15 minutes. Jack it up around 34 in the back and they come off great also.
Old Apr 30, 2005 | 08:14 PM
csexton's Avatar
csexton
Good choice. Borla's ROCK!!
Old May 1, 2005 | 12:06 AM
Crockettman's Avatar
Crockettman
Default Borla
Me and my son put my Borlas on.Hardest part is jacking the rear up high enough.Once you get it up it's a pretty easy job.Just follow the instructions.I wouldn't cut up the stock pipes.The only reason to do that is you didn't get it high enoungh.Besides..you might want them later.Also if you have somone else do it,they probably won't take the time to properly adjust them.I got the four oval tip type.If you just put them on,the tips can be at weird angles.But with a little ajusting before you tighten everything up,you can get them perfect...like a C5 should be! Either way,you'll love the sound!Good luck...
Old May 1, 2005 | 01:11 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Here's my install page......lots of pics....should calm all your fears....
http://www.nelsonresidence.com/vehic...rlainstall.htm
To Borla Stinger Install Tips?
