passanger window wont move!
Old May 1, 2005 | 02:34 AM
WRXBen's Avatar
WRXBen
Default passanger window wont move!
My passanger window wont move up or down. Any ideas what it might be? I was thinking it was the window motor, but it just doesnt move at all. Any recommendations on what to do? thanks in advance
Ben
Old May 1, 2005 | 06:44 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It sounds like it is the window regulator. A fairly common problem for the C5. When I bought my '97 the very first trip I got to take was to the dealer to have the passenger side replaced.
http://www.ecklers.com/product.asp?p...JMHVFRATGHFVFE
Paul
Old May 1, 2005 | 06:47 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
before I paid that much I would call Gene at Fred Beans and get his price.....
Old May 1, 2005 | 08:37 AM
Corvette Tommy's Avatar
Corvette Tommy
St. Jude Donor '08-'09
Ben
What year car is it?......... Are you still under warranty?
Old May 1, 2005 | 08:40 AM
pewter99's Avatar
pewter99
based on his previous posts I think he has an 01.....so unless he has ext warranty....
Old May 1, 2005 | 08:47 AM
Lancer033's Avatar
Lancer033
one other thing to check before you pull out your credit card: If the door doesn't lock and the passenger side mirror won't move, it could just be the fuse.
Old May 1, 2005 | 09:33 AM
Apoc's Avatar
Apoc
Check this out from tech tips https://www.corvetteforum.com/techti...=155&TopicID=1 it helped me as well.
Old May 1, 2005 | 10:02 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Ben
Just had the samething happen to me a few weeks ago the guys on the forum told me it might be the regulator and when i took the car to chevy and they took the door apart and told me thats what it was the regulator..
Old May 1, 2005 | 10:55 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
apply power in the appropriate direction for window travel with the button, and hold it down ....slam door. Might work.
Old May 1, 2005 | 11:57 AM
blesmess94's Avatar
blesmess94
same problem with my 03 coupe - still under warrenty, which means assuming its the regulator it will be covered right?
Old May 1, 2005 | 12:02 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
DOES the power door lock work and the switch panel light up?
If not there's a connection in the door which could be coming undone.
Chris
Old May 1, 2005 | 12:07 PM
'99 Feather's Avatar
'99 Feather
This has worked for me a couple of times now.
Now I try to make sure I cycle the window down and up whenever I get in the first time. I haven't had the problem since I started this practice.
Old May 1, 2005 | 12:16 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
I paid 170 bucks for the regulator/motor from Fred Beans when he ran the Corvette parts special...Replacing it was pretty straight forward. Be sure to mark the window with a felt tipped marker to relocate after replacement. I also found 2 more adjustments to allow the window to roll up further, thats what totally eliminated all my wind noise at high speeds!!!
Old May 1, 2005 | 01:54 PM
WRXBen's Avatar
WRXBen
thanks alot guys for all the great input
the window wont move, but the door lock and mirror still work. others i had talked to also thought it was the regulator. I will try the trick with slamming the door and see what happens. if not, then regulator it is.
thanks so much for all the help
ben
Old May 1, 2005 | 03:36 PM
blesmess94's Avatar
blesmess94
can you elaborate more on the adjustment you made to allow the windows to go up a little higher thus eliminating your wind noise. what should one look for for this adjustment.
Old May 1, 2005 | 10:52 PM
12stepvette
The window regulator clamps the window in 2 places...these clamps have vertical adjustment screws.
To passanger window wont move!
