Corvcttc
Old May 1, 2005 | 10:27 AM
JLA's Avatar
JLA
Default Corvcttc
Just put on my SS inserts. That's what I hope I don't end up with. Those little "E" inserts in the middle are awfully small and don't seem to have a whole lot to grab on to.
Old May 1, 2005 | 10:29 AM
sailohio's Avatar
sailohio
They should stay in. Mine are solid. You used alcohol to clean the plastic befor sticking the SS on, didn't you?
Old May 1, 2005 | 10:35 AM
JLA's Avatar
JLA
Yup. Alcohol and let it dry a while. Fingers crossed on this one.
Old May 1, 2005 | 10:37 AM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
Pics
Old May 1, 2005 | 10:57 AM
pewterwest99's Avatar
pewterwest99
Best Of Luck. If that doesn't work I believe i'd have to resort to super glueing.
Old May 1, 2005 | 10:59 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
what type of alcohol did you use......(no I'm not asking whether it was scotch or gin ) but I understand there are different types to use. Is "rubbing" alcohol okay?
Old May 1, 2005 | 11:11 AM
JLA's Avatar
JLA
Originally Posted by T's 99
Pics
http://img130.echo.cx/img130/6439/ssinserts002s5iv.jpg
Old May 1, 2005 | 11:17 AM
pewterwest99
Looks fantastic. Where did you order the inserts from?
Old May 1, 2005 | 11:19 AM
blesmess94's Avatar
blesmess94
mine should be here monday - would you recommend using tweezers for the middle of the E's?
Old May 1, 2005 | 11:33 AM
Slamnd Vert's Avatar
Slamnd Vert
From: mamaroneck ny www.prodigyperformancecoatings.com
i had to resort to the glue too..i prepped to perfection and after a while of washing and hose squirting some parts became loose..
note: the super glue f#$% up the paint so be aware you will always have to run the inserts to avoid repainting..
Old May 1, 2005 | 11:36 AM
JLA's Avatar
JLA
They were from West Coast Corvettes, but I got them on eBay. $45.00 I think WC wants $65.
Old May 1, 2005 | 11:38 AM
JLA's Avatar
JLA
Probably no tweezers. I think that would make it even harder.
Old May 1, 2005 | 11:39 AM
TruUndrtkr's Avatar
TruUndrtkr
i lost that part of the "E" on the front lettering kit...jot got a new kit yesterday...no more SS..
Old May 1, 2005 | 11:58 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You really should use "denatured" alcohol. There are many types of alcohols. The alcohol we drink (booze) is ETHANOL. The alcohol present in rubbing alcohol is ISOPROPYL ALCOHOL and contains as much as 30% water. You may already know that many products use alcohols. Examples are windshield washer fluid, de-icers, anti-freeze, glass cleaners, etc.. Most of these (if not all...I'm not sure) use denatured alcohols.
A denatured alcohol is a mixture of ethanol with a denaturent (there are over 80 legal denaturents available and methanol is one of them) This makes the ethanol undrinkable and ready for commercial use. A good example of a denatured alcohol is the new ethanol gasolines. This is a mixture of 85% ethanol and 15% gasoline.
So...rubbing alcohol is ISOPROPYL alcohol and a denatured alcohol is an ethanol-denaturent blend. (I am not sure if any type of alcohol blended with a denaturent is called a denatured alcohol)
Old May 1, 2005 | 03:25 PM
Lancer033's Avatar
Lancer033
I had the cheap vinyl ones on my car and had a Corvettc for a while. Cut another piece of vinyl to fill it in and eventually got a different set on there.
Old May 1, 2005 | 03:27 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
mine didn't even come out when the trash truck hit me..took a heat gun and pliers to get that part out..
Old May 1, 2005 | 03:35 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Mine have been on for over a year and lots of washing and waxing. Just be careful when using your duster or cloths that can catch on the sharp point of the 'R'. Zuti
To Corvcttc
Old May 1, 2005 | 03:40 PM
gordonb50's Avatar
gordonb50
You should be ok if you did the proper cleaning first. Mine have been on over a year with no problems.
Old May 1, 2005 | 04:05 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
They aren't that difficult to place with steady fingers
Old May 1, 2005 | 04:58 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Clean area properly and taking your time are the main things. Mine haven't budged.
