Active Handling Warming Up
Old May 1, 2005 | 06:00 PM
canadianguy's Avatar
canadianguy
Default Active Handling Warming Up
I got this message today for the first time, it just stayed on the screen for about 2min, than said warming up complete. Has anyone else had this happen?
Old May 1, 2005 | 06:15 PM
canadianguy
Ttt
Old May 1, 2005 | 06:24 PM
PJW001's Avatar
PJW001
Dont worry about this, it is perfectly normal. I usually drive especially carefully until I get the warm up complete message just in case.
Old May 1, 2005 | 06:30 PM
JH's Avatar
JH
I believe that this simply means the electronics are running through a check-process. I've seen this during a wide range of temperatures.
Old May 1, 2005 | 07:31 PM
DirteeDave's Avatar
DirteeDave
Just happened to me for the first time today. Took about 10 seconds to clear itself.
Old May 1, 2005 | 08:07 PM
DAS ZED's Avatar
DAS ZED
I have seen it several times in the past when I manually turn AH on.
Old May 1, 2005 | 08:33 PM
MY1STPEWTER's Avatar
MY1STPEWTER
I've had this happen to me two times. Both times was when I was only going around 10mph thru a park.
Old May 1, 2005 | 08:43 PM
Z0Sick6's Avatar
Z0Sick6
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
What is active handling and what does it do?
Old May 1, 2005 | 09:00 PM
My '99 had active handling and yes, this message will appear at times.
To Active Handling Warming Up
